1981 help
I got a 1981 Honda 900c and I just clean the carburetor be my self, after I put it everything back was seem to be fine, but when I start up the engine I have a very bed leak from the bottom one of those nipples and if the engine is off stop leaking.HELP
Can you take a picture of the leaking nipple you're referring to?
It sounds like a bad gasket or maybe you put one of the bowl screws in too tight and cracked it. The reason why it stops leaking when you shut the bike off might be because there's no vacuum going to the petcock and no fuel is entering the carbs once the bike is off.
Hi thank you for responding. For some reason the carburetor stop leaking but there is more issue, when I turn on the bike with choke after about 10 sec the engine loses power and turn off. Only if I push the gas does not turn off.
also if the carb leaks mabe there is a small dirt at the over flow needle at the bowl.
usally these needls get dry and they cant attach well to stop the over flow
inspect the proper function of the over flowing system. the servive-repair manual will help you how to inspect it
averyvm
12
Feb 1, 2007 08:19 PM
u2civic1
11
Feb 18, 2003 02:11 PM
