$20 Rear Stand- How To!!!
After seeing this thread https://honda-tech.com/zerothread/1995196 It made me think back to when I had my first SV and needed a rear stand. Instead of using two bar stools & some textbooks(which looks quite shady IMO) I made this one found on SVrider.com. I used it fow about 1 yr, then sold my SV, but now my friend ahs been using it still for over 2 yrs.
Link to How To Page
http://www.svrider.com/tips/pi...d.htm
Link to How To Page
Re: (Gizmo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gizmo »</TD></TR><TR><TD CLASS="quote">this only works if you have spools.</TD></TR></TABLE>
Or a couple bolts that would be less than a dollar or two.
Re: (85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 85 »</TD></TR><TR><TD CLASS="quote">i'd like to see someone with one of those at the track</TD></TR></TABLE>
Used mine at Jennings at least 3 times
Re: (.Ash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Ash »</TD></TR><TR><TD CLASS="quote">
Or a couple bolts that would be less than a dollar or two. </TD></TR></TABLE>
ya it says that in the link. My bad, I did read the info as I already have stands. All i did was see the pic of the stand with the grooves cut out and jumped to conclusions, lol.
Re: (...rohit)
My rear stand is a 3-ton car jack placed under the swingarm, where the shock linkage crossmember is. Works just fine as long as you keep the bike leaned over onto the kickstand (with a piece of wood underneath it).
For a front stand, just do the same as for the rear stand, but have a friend sit on the seat, or push down on the tail. That puts the rear tire on the ground, thus lifting the front up off the ground. Or, throw a tie strap or two over a solid tree limb or truss in a garage and lift the front up that way.
I swapped both my front and rear wheels this way in 5 minutes. Also replaced my steering bearings no problem. Nothing like being broke .
You know you have problems when you can't even build the $20 rear stand.
Re: (fatboy01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fatboy01 »</TD></TR><TR><TD CLASS="quote">My rear stand is a 3-ton car jack placed under the swingarm, where the shock linkage crossmember is. Works just fine as long as you keep the bike leaned over onto the kickstand (with a piece of wood underneath it).
You know you have problems when you can't even build the $20 rear stand.</TD></TR></TABLE>
lol yea.
found these for a pretty good price. local pick up $125 for front head/fork stand(comes with conversion) and rear stand.
http://cgi.ebay.com/ebaymotors...:1123
lol yea.
Location: hittin corners so hard you can taste my rims..
Re: (mitsuman)
there's a vendor on ebay named T-rex, not sure for exact ebay ID.. but he sells front and rear stands for about 100 bucks. 75+25 shipping... very good product. fully painted, ive been using mine for years. worth every penny.
Re: (Built B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A »</TD></TR><TR><TD CLASS="quote">there's a vendor on ebay named T-rex, not sure for exact ebay ID.. but he sells front and rear stands for about 100 bucks. 75+25 shipping... very good product. fully painted, ive been using mine for years. worth every penny.</TD></TR></TABLE>
ya but is the front stand fork and head convertible?
Re: (Built B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A »</TD></TR><TR><TD CLASS="quote">what do you mean by convertible? i know you can opt another 15-20 bucks for the tripple clamp stands.</TD></TR></TABLE>
meaning you can either use the lift off the forks, or the head. can convert from head lift to fork lift.
broketuner-Sol_Si
14
04-12-2007 08:25 AM
int3gra07
12-16-2006 10:08 PM
MattD@Stoptech
09-01-2005 08:58 PM
