Road Race Fit
Re: Road Race Fit
Last weeklend we raced the Fit in NASA class PTF.
I Won on Saturday and set a new class track record
Donna Giglo raced it on Sunday, won and set a faster track record.
Re: Road Race Fit
maybe you can find in catcams.co.uk
here are the specification
Cat Cams - Honda L15 Race Camshafts (Fit/Jazz)
* Many Durations available
* Ultra high quality, consistent manufacturing
* Custom grind tailored to your specs available, including forced induction and others.
* Duration: 290 / 272° - lift:10.10 / 9.70mm
* Duration: 290 / 259° - lift:10.10 / 9.75mm
* Duration: 292 / 286° - lift:11.05 / 9.75mm
* Duration: 296 / 288° - lift:11.50 / 10.60mm
* Duration: 309 / 292° - lift:12.00 / 11.05mm
All pre-engineered and available off the shelf
If your hitting the track with a Honda GD, fight hard with a race cam from Cat!
These race cams require upgraded valve trains and ECU, they are not suitable for stock or street vehicles.
Purchase Cat Cams - Honda L15 Race Camshafts (Fit/Jazz)
* SKU: CAT-CS-L15
* Engine Type: L15a
* Cat Cams - Honda L15 Street Performance Camshaft (Fit/Jazz)
and here the directlink
http://www.catcams.co.uk/acatalog/Ho..._1.5l_16v.html
* SKU: CAT-CS-L15
* Engine Type: L15a
Spongebrad Squarepants
Re: Road Race Fit
i have nothing to add, other than i am trying to put 2 and 2 together. given the handle and the "sponsor" on the back of the fit, you fit guys are graced by a very very fast race car driver. if it is who i am guessing, i used to crap my pants watching him race ssc when speed carried the runoffs coverage. if it is that "said" user, glad you are here. i will let you fill them in with the rest.
Re: Road Race Fit
Hello everyone,
Four SCCA regionals race wins later I decided to to a SCCA national race.
Yikes those old cars are well prepared.
But I still got second place, mostly by not breaking down ... Yeah Honda
Running some British AVON brand racing slicks now ... Boy do those tires turn RIGHT NOW !
Re: Road Race Fit
Along with camshaft services are custom Bisimoto Pro valve-springs with titanium retainers which have been spintron tested to 14,000 RPMs in harsh controlled environments with much success. Being so you will have piece of mind knowing that your valve train far exceeds your power band.
And of course Bisimoto offers the following for the L-series engines:
- Forged pistons with several options for bore and compression
- H-beam steel rods
- head porting services
- multi-layer steel head gaskets
- and much more
For more info shoot me a pm
Re: Road Race Fit
I would LOVE to build a GE for the new SCCA B spec class.... Till then I just have to make do with AutoX'ing in STF lol
What are your plans to tune it once you have a lumpy cam in there? There does not seem to be huge support for our cars, other than going full stand alone...
Re: Road Race Fit
I was just reading the SCCA rule book for HP class. And WOW they allow so much stuff just in a production class!!
I can only afford going lapping in my Fit up to a few times a year. What kinda suspension & transmission setup do you use? And what is your advice on corner weighing your suspension setup?
I just got a set of KW v2 for my car and was hoping to corner weigh it & try it out this season. However I got too busy with work & family til now. Looking to replace my spark plugs & ignition coils this winter, and pray the next season will be here soon.
Must be expensive to run, and WIN in one series. Two thumbsup to you, sir!
Re: Road Race Fit
Yes get your car corner weighted as soon as possible.
Any time you get a part that can be adjusted think that it is out of whack.
That will serve you well with all race parts.
user 25438239
13
07-29-2010 08:54 AM
