Hi, I have a 2008 Honda Fit. I tried to locate the Coolant Temperature Sensor and change it but I couldn't find it. Can anyone tell where I can find it and how to change it?
Many thanks!
Many thanks for answering the question. Do you happen to have a photo for the location of ECT2 senor? I tried to locate it but had no luck.
Do I need to drain the coolant before I take off the sensor?
It is at the bottom of the radiator on the passenger side (right side). Normally, the coolant is drained; however, if you do it quickly enough, you won't have to drain it all. Part # 13 in parts diagram.
