Coolant temperature sensor
Hi, I have a 2008 Honda Fit. I tried to locate the Coolant Temperature Sensor and change it but I couldn't find it. Can anyone tell where I can find it and how to change it?
Many thanks! |
Re: Coolant temperature sensor
There are two Engine Coolant Temperature sensors; ECT 1 and ECT 2.
ECT 1 is located on the cylinder head below the throttle body and ECT 2 is located at the bottom of the radiator. |
Dear tech8,
Many thanks for answering the question. Do you happen to have a photo for the location of ECT2 senor? I tried to locate it but had no luck. Do I need to drain the coolant before I take off the sensor? Thanks again! |
It is at the bottom of the radiator on the passenger side (right side). Normally, the coolant is drained; however, if you do it quickly enough, you won't have to drain it all. Part # 13 in parts diagram.
https://cimg3.ibsrv.net/gimg/honda-t...eaaf27ddc5.jpg https://cimg3.ibsrv.net/gimg/honda-t...dc214b1567.jpg |
Dear tech8,
Thanks so much for the attached photo and diagram. I will look for it again. |
