Honda Fit Honda Fit (Jazz)
2004 GD1 Jazz - Fault Code 8 TCD Sensor?
Old Aug 27, 2025 | 03:51 AM
lraw's Avatar
Icon5 2004 GD1 Jazz - Fault Code 8 TCD Sensor?
The check engine light has been on intermittently for a while. When the light is on, the engine 'hunts' on idle but still drives fine. If I unplug the battery, the light will go off for maybe 1 or 2 trips but then come back on. While it's off, it idles fine but when on it will hunt again on idle.
I've pulled the CEL code by jumping the diagnostics plug and counting the CEL flashes. It's fault code 8 which I believe is TDC (Top Dead Centre) sensor.
Has anyone had this error before on a Jazz and fixed it?
What I've tried already:
  • New Cam Sensor
  • New Crank Sensor
  • New Spark plugs (they were due anyway)
  • Cleaned out the EGR
  • New oil and oil filter (this was due as well)
I read that this error is sometimes caused by timing being out due to a stretched chain but don't want to go down the route of chain replacement unless it's 100% the cause as that's a much bigger job!
I also read on some older Honda's the TDC sensor is inside the distributor but the GD1 Jazz ignition is ECU and Coil controlled so no distributor. Could it be a dud ECU or coil?
Any suggestions appreciated.
Cheers
L
Fastmike5
Mar 17, 2017 12:56 AM
maat4449
Honda CR-V & Element
Jan 10, 2011 10:58 AM
Eli Mac 67
Jun 8, 2007 02:30 PM
hybridEj6
Sep 11, 2003 06:41 PM
Eluzion
Jun 20, 2003 12:08 PM
