Honda CR-V & Element 2WD & 4WD Element & CR-V
no constant 12volts to many things
Old 09-25-2017, 08:44 AM
jedkin's Avatar
Default no constant 12volts to many things
I have a 2003 honda crv base model i just purchased. As i was getting it ready for inspection i found the brake lights, the horn, the radio, the door locks, the dome light, and the dlc have no power. I ran a new ground wire from the battery to under the steering column bolt. still nothing also i get no chimes with the key in? any help?
Old 09-25-2017, 07:22 PM
Occidentalis's Avatar
Default Re: no constant 12volts to many things
All of that is in a few positions in the under dash driver's side fuse box, it might be worth a look to inspect those fuses. There is a basic printout of the fuse layout on the back of the piece you remove to gain access.
2TrippleOhSi
06-07-2011 08:00 PM
ketchup
29
03-27-2009 09:33 AM
Gvis420
09-18-2008 06:28 AM
JarvisW
Audio / Security / Video
06-07-2007 09:09 AM
BLACK_DEL_SOL
01-11-2005 08:38 AM
Quick Reply: no constant 12volts to many things
