2000 CRV White Smoke Engine
Here is the video i've uploaded on youtube
and
What happened was Ive already drained the oil to proper level due to over Filled the engine oil. The white smoke will appears every time engine running on idle about 2 mins and on.
But that Smoke is not coming from inside the Dipstick hole, neither from the oil filler cap,
Coolant it was at proper Lvl. The coolant pipe is cold to touch as you can see in the video moisture and wet.
Temp Gauge is at C, both of the fan is not running unless i turn on the A/C.
Tail of Exaustion Pipe NO SMOKE but have small amount of water.
Well, I took it to the Pepboys and did the Drain again , now i have new oil,new oil filter and new air filter. the thing is it didnt fix the problem.
white smokes still coming from the bottom of the crankcase. Any Help will be great.
Im thinking about Sea Foam first then Flush the Engine, then drain oil again.
So far Ive watched this video and its pretty convincing PRO-TEC Engine Flush
Let me know ASAP if there are risks of danger to driving around like in this situation.
Thank u.
Thank u.
magicguy
10
05-11-2011 08:09 PM
