zc in a 4g civic help me!
i bought a 1990 civic si with a blown engine for dirt cheap i ordered a DOHC zc engine for it ( this is my first swap by the way) but now im a little confused on the wiring .i bought it from hmotorsonline.com and they just cut the harness in half . how do i get all my wires to match up. The plugs are different sizes and shapes
use your original harness from the old motor and add the required plugs if need be. take a look in the faqs section to figure out what you need to do. its not hard to swap an engine even if it is your first. take a ponder in there, there is tons of information to be had.
also is/was your car dpfi or mpfi?
if you have a civic Si, then the only thing you will really have to change is the distributor wiring.
You should already be at Multi port if you are at a civic si.
check this out
http://fourthgenhatch.net/zc.html
check this out
Oh cripes. Mine just plugged right in, but someone might have done something weird to my car before.
ummmmmmmmmmm
you can depin the plug and get the one off the old harness and put the pins in? Just match the colors up. THat's my best advice.
ummmmmmmmmmm
gregv
09-11-2002 03:24 AM
vtec_head
05-08-2002 08:59 AM
