Will 88 CRX Si door panels fit 90-91 doors?
Old 04-14-2009, 10:44 PM
Ldo
Ldo's Avatar
Default Will 88 CRX Si door panels fit 90-91 doors?
I just did the pillar seatbelt conversion on my 90 CRX Si. Someone is selling a nice set of 88 Si door panels with the side pockets. Now that the seatbelt assembly is removed from the door, will the thinner 88 panel fit or am I missing something?
Searched but did not find the answer.
Old 04-14-2009, 10:49 PM
crx_si-r's Avatar
Default Re: Will 88 CRX Si door panels fit 90-91 doors?
im not sure if they will fit. but seeing as you already removed the seat belt assembly they should. what you could do is take the passenger side door panel off and take your car to who ever is selling the door panels and test fit it.
88_acED6's Avatar
i tried to put 90-91 panels on my 88 hatch they wouldn't fit
Old 04-14-2009, 10:52 PM
crx_si-r's Avatar
hold on after re-reading your post i dont think they will work, mainly because i believe the 88 doors are slightly longer than the 89-91 doors. can any one confirm this?
Old 04-14-2009, 10:55 PM
88_acED6's Avatar
they are...the panel was about an inch too short
Old 04-14-2009, 10:56 PM
88_acED6's Avatar
but its 88-89 are different from 90-91
Old 04-14-2009, 10:58 PM
Ldo
Ldo's Avatar
OK thanks.
Damn it. Why did Honda ruin a good thing for us in the US?
Old 04-15-2009, 08:48 AM
hushypushy's Avatar
Only for hatches. He was right in the first place, 88 CRX is different than 89-91 CRX (except 89 HF).
I think the doors are the same size, but the panels are not interchangeable. Try getting some 88 or JDM doors?
Old 04-15-2009, 09:04 AM
jaypain's Avatar
88 or jdm doors will not solve his problem. the shape of the door will physically close on a 89-91 body, but not properly...door seal and shape is different. best solution is to modify the top of the door itself to accept the 88 panels. that way your doors seal. only about 1/2 in. of metal needs to be reworked near the pillar on the inside. i had to do this to fit my edm panels to my 91. fits perfectly and it's clean.
EL Vap133's Avatar
That is correct!
Old 04-15-2009, 02:40 PM
hushypushy's Avatar
And this was on a CRX, correct? I wonder if it's the same for hatches. I would looooooove some LHD EDM door panels on my hatch.
Old 05-01-2009, 01:46 AM
Navy_CRX's Avatar
will a set of edm crx doors fit on a 91 crx si???
Old 05-01-2009, 07:43 AM
clovis88crx's Avatar
91 doors are different so they will not fit 88 door panels.
Old 05-01-2009, 08:35 AM
mitsubishiv5's Avatar
they wont fit. if you try to fit 88 crx doors with pillar mounted seats onto a door mounted 90-91 crx the outline where the door meets the quarter panel has a different shape, the 88 on the 90-91 crx will be too big and your going to have to dent in the door to improperly fit it, so it would be vise versa for the other 90-91 door onto 88. that means youll run the door panel into the crease and **** them up..... So the answer is no, i wouldnt kill your perfectly great crx for some dumb door panels. just get the 88, and drill the pockets into the panel.
Old 03-03-2010, 01:44 PM
cuevasdc2's Avatar
ok do u no if civic hb doors fit a 91 crx
Old 03-03-2010, 05:41 PM
Is Partying at your House
Dc4iNtEgRa's Avatar
I need a good condition passenger side Si panel for a 88.
Old 03-08-2010, 05:13 PM
Ldo
Ldo's Avatar
Bring back from the dead just to update:
88 USDM, 88-91 EDM & 88-91 JDM CRX panels will fit into 89 DX/Si & 90-91 CRX's IF AND ONLY IF you do the following:
1. Relocate the seatbelt to the pillar.
2. Trim about 1 square inch where the 88 panel meets the pillar.
Everything else lines up except for 2 plastic clips at the bottom because of where the seatbelt was in the original USDM door. Just don't use those clips.
Here's how they are stacked up and you can see what you need to trim, bottom is EDM panel (which is same as any other panel from CRX with pillar mounted seatbelt):
Again, CRX door panels only. Don't ask me about EF Hatch or Sedan.
Old 01-09-2012, 10:54 AM
88crxmodder's Avatar
Does anyone know if you can get del sol doors to fit on an 88 crx?
Old 01-09-2012, 11:54 AM
crvtectim's Avatar
I'm sure someone from the 3 year old thread you bumped will reply shortly.
Old 01-09-2012, 12:06 PM
jlk16188's Avatar
Just buy a del sol and a crx. They arent even close bud
Old 01-09-2012, 01:09 PM
BigbamaBen's Avatar
Fml. I'm glad you did this in a way. So if i have an 88 Crx and try putting 91 in then they will be an inch short? Any problems in putting it in?
Old 04-19-2014, 07:39 PM
CRX ANT's Avatar
I know this post is really old but I'm having the same issue right now and hope I can get a reply. Are you saying I have to cut the door panel a little bit or the door itself?
Ryude
07-10-2018 05:55 AM
tonytruongrahs
04-17-2008 04:47 PM
intense_imports
03-31-2007 09:09 PM
B2FiNiTY
20
12-13-2003 09:46 AM
Quick Reply: Will 88 CRX Si door panels fit 90-91 doors?
