what type of oil for ac?
Old 07-16-2014, 12:02 PM
Ef4doorwagon's Avatar
Default what type of oil for ac?
89 civic- replaced evaporator with one that uses r134, so the expansion valve is r134 specific. And the drier is also for that. Also the condensor( came with the car that had 134 in it) I believe is134 but i could be wrong.
I am using stock high and low pressure lines that came in my 89 and stock compressor.
Now according to this link http://www.techchoiceparts.com/refrigerant-and-oil-capacities/efgh
It says refrigerent is originally r12 and requires 33 oz of it and uses mineral oil.
Now my question is how much r134 do I use in my system? And what compressor oil do I use ( the pag6?)?
If this has been answered, sorry and if you could post the thread that wouls be very helpful, thanks.
Old 07-16-2014, 12:06 PM
Default Re: what type of oil for ac?
*also I am using those r12 to r134 adapters
I will be using a vacuum pump and ac manifold gauge to recharge the system
Old 07-16-2014, 01:10 PM
ej1995's Avatar
still use the mineral oil. use the same amount of r134a that you would use of r12
Old 07-16-2014, 01:53 PM
From what I read is that its best to use ester oil( pag) with 134 because of what 134 is made of. This info is applied to a sanden r12system retrofitted to 134, but mine is a mitsoshua or whatever, so idk if the same things apply.
Old 07-16-2014, 02:11 PM
jonGSR's Avatar
Are you removing all of the old oil from the system completely?
Old 07-16-2014, 02:40 PM
I was thinking I should unbolt the compressor and dump the oil, my lines dont really have any in them( used compressed air)
Old 07-16-2014, 04:50 PM
99teggsr's Avatar
Use ester oil. 6OZ total for a 100% drained Sanden system. R134 you use less gas than R-12, about 24-26 oz.
ESTER oil is for R-134 retrofits as it is compatible with the R-12's mineral oil. I believe the PAG's are used when your car was originally R-134.
Old 07-19-2014, 02:07 PM
Ok thx for the info. Im draining my compressor of oil by tiliting it, and wanted to know if I should add 2 oz to the high side and 2oz to the low while my compressor is off the car?
Or should I vacuum the system, then before refilling with freon, should I add the oil using the 3rd yellow hose?
Old 07-20-2014, 03:00 PM
sstupid's Avatar
If you vac it out long enough it will boil off all the old oil.
Old 07-21-2014, 06:58 PM
Ok I vacuumed the system about an hour. The low side gauge reads at 21hg and the high side is at 0. The high side was below 0 while vacuuming but after sitting its at 0. Is 21 hg too low? Does it mean theres a small leak??
Old 07-23-2014, 08:21 PM
xprometheusx's Avatar
if there is a small leak its probably just a oring some wehre better just to use R134 with some kind of leak sealer. i also like to add dye into my refr or buy it with it already in so i can find future leaks.
Old 07-24-2014, 05:28 AM
99teggsr's Avatar
Did you shut the ***** at the manifold and let it sit ? I found my vacuum had a leak in it and without shutting off the manifold ***** it would leak through the vacuum, but my system was actually leak free.
Old 07-24-2014, 10:34 AM
I did shut them closed. To explain better, with the ***** off, hooked up to the pump, i turned the pump on then opened just the Low side, it reached 28hg in, which I think is what its suppose to be at. Then I opened the high side **** and the low side droppsd to 22 and the high side gauge went below 0. Then I shut both valves closed and turned the pump off. I watched the gauges, the low side sat at 22 but the high side immidiately went from being below 0 to staying at 0.
Old 07-27-2014, 03:14 PM
Bump
cliffbrown
05-03-2018 12:33 AM
Zebra
Honda Civic (2006 - 2015)
02-08-2018 08:21 PM
nwf_snake
04-08-2008 08:41 AM
AndyD
04-25-2005 10:17 AM
TenaciousC
09-25-2002 06:43 PM
Quick Reply: what type of oil for ac?
