what fuel pump to GET? (b16..)
Old Aug 17, 2006 | 04:15 PM
1_slow_crx's Avatar
Default what fuel pump to GET? (b16..)
well my car is acting very weird. there is very low fuel perssure at the fuel lines in the engine bay. and at the same time seems to be running rich. all this black junk on the rear of rear from exhaust. i need told that the filter could be the problem. or the pump. well i have changed the filter.
is it the pump?
oh yeah and because it has low pressure... while at a speed . (say 35) if i slowly give it gas it bogs/ starving. like its not getting enought gas.
help?
which should i get?
CRX 1989-1991 190 LPH
CRX 1989-1991 255 LPH
CRX 1989-1991 255 LPH High Pressure
Modified by 1_slow_crx at 8:40 PM 8/17/2006
Old Aug 17, 2006 | 05:16 PM
hybridmiklo's Avatar
Default Re: what fuel pump to GET? (1_slow_crx)
If you are running a b16 with just bolt ons or non turbo just get the crx si fuel pump. That's what I did when my hf pump was going out. That's also what Church the tuner recommended. No need to spend money on aftermarket.
Old Aug 17, 2006 | 06:02 PM
charlee's Avatar
Default Re: what fuel pump to GET? (hybridmiklo)
well here the retail for a walbro is less close to $80 than one from autozone or checkers, havent checked pepboys, but im sure theyl be the same. i cant remember what brand it was tho
Old Aug 17, 2006 | 06:07 PM
1_slow_crx's Avatar
Default Re: what fuel pump to GET? (charlee)
walbro is cheap...
which should i get?
Old Aug 17, 2006 | 07:39 PM
1_slow_crx's Avatar
help?
Old Aug 17, 2006 | 07:41 PM
slowcrxsib16's Avatar
on my turbo b16 i put a walbro 255lph high pressure in it, it ran me like 109 with tax, good upgrade if you dont want to worry about it
Old Aug 17, 2006 | 07:48 PM
CRXBart's Avatar
Default Re: what fuel pump to GET? (slowcrxsib16)
190 is more than enough for a b16. Do you plan to do more to it? BTW if you go with a HP you will need an adjustable FPR so you can tune the fuel down. There is place on Ebay you can get 255hp for $99 shipped I just got one this week.
Old Aug 17, 2006 | 08:40 PM
1_slow_crx's Avatar
Default Re: what fuel pump to GET? (CRXBart)
as of now i dont plan on doing anything to engine. maybe big intake manifold. i have intake/header/ and exhaust. im getting new brakes and then i need new suspension.
Old Aug 18, 2006 | 08:30 AM
Reelizmpro's Avatar
I got my 190 Walbro from a business on Honda Tech for like $79 shipped. I think it was Lightening Motorsports. It's plenty fuel flow for a NA B16.
Old Aug 18, 2006 | 08:49 AM
gmoneyef's Avatar
Curious... I have the same problem and need to change mine out.
Q: Can you purchase a fuel pump with too much flow with a fpr connected?
Reason asking is that I plan to boost, but not now and I need to replace now. Rather purchase what I need than to buy two.
hmonkey86
Feb 7, 2012 05:02 AM
lxiaccord
24
Jun 1, 2009 11:43 AM
camo_crx
31
May 10, 2006 08:16 AM
Kampfer
Mar 14, 2005 02:24 PM
Leperchon
Jan 8, 2004 06:28 PM
