Tach, fuel guage, temp guage all not working...fuse??
Like title states, tach, fuel guage, temp guage all aren't working. I dont' know if they ever did as I'm restoring this car. Check engine lights, turn signals work. ideas? is there a fuse that controls those somewhere?
btw 88 hatch DX, 89 si cluster, known working cluster, I saw it working in another car.
Re: Tach, fuel guage, temp guage all not working...fuse?? (meallout)
i went through the same problem your best bet is to search on here and theres a post about how to repin the conectors to match up with the right function.
Re: Tach, fuel guage, temp guage all not working...fuse?? (kenlrw39)
I have the same problem. Everything is stock. 91 CRX Si. My check engine light doesn't come on during start up either. Someone help us out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meallout »</TD></TR><TR><TD CLASS="quote">speedo works, as its not electronic.....</TD></TR></TABLE>
I just got mine to work. It was the fuse. And now my speed still doesn't. So that totally makes sense.
My tach on the other hand has a jumpy needle past 3500 RPM's. Anyone know ho to fix that?
Re: Tach, fuel guage, temp guage all not working...fuse?? (meandino)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meandino »</TD></TR><TR><TD CLASS="quote">And now my speed still doesn't.</TD></TR></TABLE>
Your speedo works off of the cable thats plugged into the rear of your cluster, it may not be tight or all the way on there. Pull it off, then push it firmly into the back of the cluster, if you hear a "click", its on there.
My tach on the other hand has a jumpy needle past 3500 RPM's. Anyone know ho to fix that?</TD></TR></TABLE>
a bad igniter (ICM) can cause the tach to bounce around/be "jumpy".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meallout »</TD></TR><TR><TD CLASS="quote">Like title states, tach, fuel guage, temp guage all aren't working. I dont' know if they ever did as I'm restoring this car. Check engine lights, turn signals work. ideas? is there a fuse that controls those somewhere?
btw 88 hatch DX, 89 si cluster, known working cluster, I saw it working in another car.</TD></TR></TABLE>
the fuel gauge is connected to the fuel gauge sender unit, temp gauge is connect to a sensor on the block, and tach from the distributor. are all of those things hooked up?
you're restoring the car so, is the motor running? what state is the car in?
Are you positive that the cluster is from an 89, cause the 90-91 pinouts are different. although I believe if you did have the wrong year cluster all the features would still work but they would be all mixed up.
are all the screws in place and tight in the back of the cluster, they connect the curcuits on the gauges
please tell me you've at least checked the fuses by now.
Modified by grog at 12:22 PM 8/3/2008
Re: Tach, fuel guage, temp guage all not working...fuse?? (tehondafrk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tehondafrk »</TD></TR><TR><TD CLASS="quote">Your speedo works off of the cable thats plugged into the rear of your cluster, it may not be tight or all the way on there. Pull it off, then push it firmly into the back of the cluster, if you hear a "click", its on there. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meandino »</TD></TR><TR><TD CLASS="quote">So that totally makes sense.</TD></TR></TABLE>
Thanks for you're help.
Re: Tach, fuel guage, temp guage all not working...fuse?? (grog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grog »</TD></TR><TR><TD CLASS="quote">igniter (ICM)</TD></TR></TABLE>
That's the one inside the dizzy next to the coil, right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meandino »</TD></TR><TR><TD CLASS="quote">Thanks for you're help.</TD></TR></TABLE>
No problem
No problem
That's the one inside the dizzy next to the coil, right?</TD></TR></TABLE>
yes.
yes.
Re: Tach, fuel guage, temp guage all not working...fuse?? (efsublime)
I own a 94 civic sedan dx and the problem I'm having is the light on the cluster turns on but the rpms, mph, temperature and fuel gauges don't move/work. At first i though the cluster it self was the problem so I went and bought another one; however, i'm still having the same issues. Has this happen to someone else before? Plz help its driving me nuts...........
I just got a guage cluster from a 92-95 ex sedan to put into my 94 cx everything works except the fuel guage can anyone help? The one I had in there before worked
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meallout »</TD></TR><TR><TD CLASS="quote">speedo works, as its not electronic.....</TD></TR></TABLE> what fuse did you change to get the fuil gauge working again??
This is a really old post but I have the same problem on my 1991 civic hatchback
I got into a minor accident and had body work done on my car. On my way to the shop all my gauges worked, but a couple days later after my car was done they stopped working. I only got my speedometer to work again because I pushed the VSS back in place. Also my emergency lights are not working..ANY HELP PLEASE??
On my 89 Honda Prelude Si the fuse is the one for the turn signals (10 amp).
98GSR-Turbo
03-12-2009 04:50 PM
Augustin
07-02-2007 04:51 PM
