starter spinning, not engaging flywheel
Old 12-28-2006, 09:50 AM
G60
G60's Avatar
Default starter spinning, not engaging flywheel
Finally got the starter moving. Tried to get the car started up, at first it turned over a few times, refilling fuel lines etc since everything drained when I swapped the motors. It started to catch, then stalled out. Tried again, and now the starter doesn't seem to be engaging the flywheel, I just hear it spinning away. I'm ready to set this friggin car on fire...any ideas?
G60 is offline
Old 12-28-2006, 12:20 PM
e jay one's Avatar
Default Re: starter spinning, not engaging flywheel (G60)
your starter sylonoid is bad or sticking just get another starter this happened to me.
e jay one is offline
Old 12-28-2006, 02:04 PM
G60
G60's Avatar
Default Re: starter spinning, not engaging flywheel (e jay one)
The solenoid is fine. When I turn the key, the starter is spinning. Even if the starter is not wired to the solenoid, when the key is turned you can hear the solenoid clicking over. I'm not sure if the starter motor itself has worn out, or if it just needs some lube or what. It was working fine before I did the motor swap.
G60 is offline
Old 12-28-2006, 02:14 PM
JT2MA71's Avatar
The gear isn't being pushed out. Get a new starter.
Happens all the time with ma70 supra starters...they'll spin fine, but won't push out to engage the flywheel/flex plate.
JT2MA71 is offline
Old 12-28-2006, 04:43 PM
e jay one's Avatar
Default Re: (JT2MA71)
well mine did the same exact thing it would work sometimes and sometimes just spin so get another one.
Old 12-29-2006, 10:10 AM
colnago's Avatar
i agree, your starter motor is fine, but sounds like your solenoid is not causing your gear to come out. replace starter or find a used solenoid at the junkyard.
cheap fix.
colnago
colnago is offline
Old 12-29-2006, 11:31 AM
G60
G60's Avatar
Default Re: starter spinning, not engaging flywheel (colnago)
I thought the gear came out on the splines, through centribugal force? Not because the solenoid pushes it out.
G60 is offline
Old 12-30-2006, 06:25 PM
colnago's Avatar
true, the solenoid is like a relay that allows battery power to starter motor, it also allows the bendix gear to come out to engage flywheel.
it's a little more complicated than that, as there also is a overrunning clutch that could be slipping an not allowing gear to come out.
colnago is offline
Old 12-30-2006, 06:44 PM
Tippyman's Avatar
Just get a new starter, trust me. Don't ask how I know. Those soldenoids are easy to get fucked up.
I got one at a junkyard for like $8.It's easy, simple, and will most likely fix ur problem. And hell, if it doesn't, you know the problem lies elsewhere.
Tippyman is offline
Old 10-13-2020, 12:58 PM
John Will's Avatar
I'm having a similar problem but I got a new starter and it's the same
​​​The starter will spin and make a grinding noise but no start
John Will is offline
dmanfree
06-21-2013 12:38 PM
GoneImport
02-18-2008 06:45 AM
h22a_black
02-13-2008 06:12 AM
383chevy
01-25-2007 07:58 PM
cstay
05-14-2004 06:30 PM
Quick Reply: starter spinning, not engaging flywheel
