REAR DISK BRAKE CONVERSION w/pics
#28
1 Post
Re: REAR DISK BRAKE CONVERSION w/pics (bluelsvtecda9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluelsvtecda9 »</TD></TR><TR><TD CLASS="quote">wats brake lines do u use the da or ef</TD></TR></TABLE>
either one will work, 90-91 crx si or 90-93 integra will both work fine
#30
Re: REAR DISK BRAKE CONVERSION w/pics (Angry)
im putting 90 integra rear brakes on my 88 crx does everything bolt right up, trailing arm, and every other arm off of the trailing arm?
#32
Re: (ED9man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ED9man »</TD></TR><TR><TD CLASS="quote">I didn't have to touch the tank on my CRX, maybe the hatch is different.</TD></TR></TABLE>
#35
Re: (Bejita)
um wat taillights if u read the post u would see that this was done 2 my friends car and that i tried to get him to change em.
#37
Re: REAR DISK BRAKE CONVERSION w/pics (crx_si-r)
i just did a rear disk setup on my 89 dx hb using 91 crx si rear disks & swaybar, DA integra E-brake cables bc the crx ones are to short for a HB, Da integra 40/40 prop valve, brand new Crx Si master cylinder w/lifetime warranty from autozone, new oem rear rotors w/ ceramic pads, front brembo cross drilled /slotted rotors w/ ceramic pads, and Stainless steel Braided brake lines . and i can stop on a dime.. iv never been more happier
#38
be professional
Why did you drop the fuel tank? That is totally unnecessary. You just created a lot more work for yourself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super79Dave »</TD></TR><TR><TD CLASS="quote">Oh and you missed changing the proportioning valve. 4040</TD></TR></TABLE>
The 4040 is not the correct proportioning valve for a Civic with 7CLP13S rear calipers and the stock small unmarked front calipers for 9.5" discs. The correct proportioning valve for that setup is from a '92-95 Civic EH3 Si non-ABS.
The 4040 is used for 7CLP13S rears with 17CL14VN fronts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EatSleepJDM »</TD></TR><TR><TD CLASS="quote">im putting 90 integra rear brakes on my 88 crx does everything bolt right up, trailing arm, and every other arm off of the trailing arm?</TD></TR></TABLE>
Do not, I repeat, DO NOT use any arms from the Integra other than the trailing arm, or else you will have major wheel alignment problems. The trailing arm is the ONLY arm you can use from the Integra.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_CRAZY07 »</TD></TR><TR><TD CLASS="quote">94 integra ls rear brakes work on a 91 crx done this same way?</TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW-ITR »</TD></TR><TR><TD CLASS="quote">So, did you swapped out the E-brake cables also or you re-used the E-brake cables?</TD></TR></TABLE>
You can't reuse your cables. You have to use DA Integra cables (on a Civic) or '90-91 CRX Si cables (on a CRX). The fittings are different for drums vs. calipers.
Yes.
#39
Re: (CRX_CRAZY07)
Yo I got my rear disks off a 94 teg.. I am gonna be putting them on within the next few weeks.. From my search I found everything is gonna work, but I am gonna buy some 90-93 brake hoses. I will let you know how it works out when I am done.
#40
Re: REAR DISK BRAKE CONVERSION w/pics (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote"> The correct proportioning valve for that setup is from a '92-95 Civic EH3 Si non-ABS.</TD></TR></TABLE>
this is important enough that i need to ask for you to justify this.
#41
be professional
Re: REAR DISK BRAKE CONVERSION w/pics (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">this is important enough that i need to ask for you to justify this.</TD></TR></TABLE>
I don't know if I even want to go there Why bother even changing the prop valve from stock at all if you're just going to put another wrong one on?
#42
no really. please explain your logic.
im not questioning you. i will probably agree with you. i just want to know why you make such a statement.
#43
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">no really. please explain your logic.
im not questioning you. i will probably agree with you. i just want to know why you make such a statement.</TD></TR></TABLE>
Ask yourself this: Why would a 4040 be the correct proportioning valve for the D273/9.5" unmarked front calipers with 7CLP13S rears? A car with such a configuration was not given a 4040 valve. The only car that ever came stock with that configuration from Honda was the non-ABS EH3. 4040s were found on cars with 17CL14VN fronts and 7CLP13S rears.
You and I both know that trying to decipher the proportioning valves are a crapshoot anyway. I've just defaulted to recommending a valve from a car with the closest stock brake configuration to the intended hybrid setup (with some exceptions being made for '96-00 Civics).
#45
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">so what valve does the eg civic have?</TD></TR></TABLE>
Don't know, but I'd be interested to find out, so I could see if any other cars shared it. I haven't had an EH3 in the junkyard for over 2 years.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">what MC?</TD></TR></TABLE>
13/16".
13/16".
#47
be professional
I hate the EG forum. They only answer questions that deal with JDM road flares and carbon fiber center caps for Rota wheels. Good luck getting a technical answer
#50
3040. non abs Si
3040. non abs Si
