Radiator and Heater Hoses for B16A in CRX
Old 11-13-2012, 05:16 PM
tacchan's Avatar
Default Radiator and Heater Hoses for B16A in CRX
Im putting in a b16A into my CRX and I need to put in new radiator and heater hoses.
For what makes and models can I get these parts for?
CRX Radiator upper and lower hoses + any B-Series Heater hoses?
Any help is greatly appreciated.
Old 11-13-2012, 06:46 PM
ED3 SEDAN-GSR's Avatar
Default Re: Radiator and Heater Hoses for B16A in CRX
I just used the same heater hoses from my d series. Now for the rad hoses i put in a full length rad from a 90-93 teg. They have b series engines already so b series size hoses fit without having to stretch them or over tighten them to get to seal. I did this on my 91 sedan with a gsr swap
Old 11-13-2012, 07:04 PM
tacchan's Avatar
I have a full size rad on my CRX already. I already replaced the upper hose with one for a CRX, so I am guessing that I can use a CRX lower rad hose too?
Old 11-13-2012, 07:10 PM
1998GsRIntegra's Avatar
Have had various B-motors in mine and always used 93 integra rad hoses. That is with a full size rad though.
Old 11-13-2012, 07:41 PM
tacchan's Avatar
Im confused. From what you guys are saying, both CRX and Integra heater hoses/radiator hoses will work....
So will both types work?
Old 11-13-2012, 10:38 PM
The original single cam rad hoses are smaller (in diameter) than the b series hoses.
You CAN use the single cam hoses on your b series engine but you will have to stretch them over the ports where they connect to the engine.
Some ppl use the bigger b series hoses with the d series radiator, they just have to really tighten the clamp.
This is why i said i used a 90-93 radiator so all the ports for my coolant hoses were the same. I hope this does not further confuse you.
Old 11-14-2012, 03:27 AM
ef92b's Avatar
^what he said.
it's best to use new hoses(single cam) so they can stretch and slide in easily rather than re-using the old and brittle hoses.
Old 11-14-2012, 06:11 AM
tacchan's Avatar
Thank you. So it looks like the CRX Radiator and Heater hoses will be what I will be using!
Old 11-14-2012, 05:23 PM
tacchan's Avatar
Im still confused. Epic Autosports said that I need the 93 Integra Upper and Lower Radiator hoses and I can re-use my CRX hoses.
Should I just get ALL Integra Upper/Lower and Heater Hoses?
blake22
04-14-2008 08:06 AM
w2 cor
07-04-2007 11:47 PM
msinsky14
02-17-2007 02:10 PM
crxnug
02-03-2006 07:26 PM
buddha1320
01-20-2005 09:17 PM
Quick Reply: Radiator and Heater Hoses for B16A in CRX
