Quick wiring question
I am looking to pick up a 88 Crx hf (factory mpfi)from a buddy it has no engine harness and I searched around and really didn't find an answer to my question. I want to know if I could use an obd0 integra harness as they are easier to find in salvage yards. Motor would prolly be a sohc motor is that makes any difference
Thanks
Thanks
Re: Quick wiring question
Does the motor make a difference I just wanna know if it'll plug in the motor won't be original it's just a shell if I have to modify the harness it's not a problem to me and I won't be running egr car will prolly run on a pm6 ecu....the guy who has the car used the harness off the hf To run his Si (although it's swapped)
Found what I needed here will the apply to da harness?
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/si-harness-hf-car-2164764/
https://honda-tech.com/forums/showthread.php?t=2164764
Do you happen to have the pinout for the da harness?
Or another thought maybe even a first gen integra harness
ITSTOCK
11-15-2003 03:51 PM
