need help with b16 swap in an 89 ef
yo I have 89 ef hatch, I wanted to know if 91 integra axles will work on the dx hubs or do I need the hubs from the teg and will the axles go into the y1 trans.....
please help
also what are all the parts i need for the swap
please help
Re: need help with b16 swap in an 89 ef (highrev1987)
The axles will work but you will have to take off the dust seals from the dx. If I were you I would suggest to use he integra knuckles if you can. Bugger brakes and will be a big brake improvement. You will need mounts, shiftlinkage, ecu, wiring harness, and a few other things, check this forum out for more info,
https://honda-tech.com/zerothread?id=1508680
MEBHB91
08-10-2006 12:09 AM
4gencivicef9
03-12-2006 02:34 PM
