My build thread-1991 usdm honda crx si d16a6 sohc zc all motor N/A
#252
Re: My build thread-1991 usdm honda crx si d16a6 sohc zc all motor N/A
came out legit, no supports(although probably should have)
Feels so good, I made them 50 mm spheres just because all the ones I measured were @ 53 54 55 mm and they felt too big. The 50 is perfect, keeping this, like it more than my moogen.
People at stop lights would creep forward and compliment it.
2.75 hrs.
lots of warping at the base, but it's part of the charm of 3d printing
2.75 hrs.
#255
-Intl Steve Krew
#256
You're both in luck, I just ordered some pink filament, and a dark gray as well.
That 50 mm sphere is hard to print but if I split it it works out pretty well I still like how F***** the green one looks though =p
#259
Haven' posted in a while but I made a lot of shift *****, made a gopro adapter specifically for honda/acuras, a horn delete plate, keychain, replacement dead pedal insert. Took off my clusster cover to see if I could find this rattle that was happening behind my cluster. It was the speedo cable, I put a ziptie on it, around the foam covered section and just tensioned it and the noise went away. You're suppose to remove the entire cable from the housing and lube it. But that seemed too hard for me.
You see I put orange electrical tape over my mirrors in hopes of increasing visibility. Which doesn't work at all, because someone who's not looking won't see you. No matter how visible your car is. I also added a rear fog light( more info on this later)
Pictured is my front splitter, which I never showed in photos.
#262
hehe, thanks, it's just crayola marker. Surprisingly it held up too. And completely removeble with water alone.
I wanted to do them the yellowish color that the type R's had but the crayola marker was not strong enough to show.
It's actually one coat of orange, one coat of red and one final coat of orange.
#263
-Intl Steve Krew
You need to wetsand, spray a few more coats of paint, and wetsand again
#266
That's plastidip, can't sand, just recoat. maybe a lil glossifier to protect. but I don't like the sheen of the plastidip glossifier
#267
-Intl Steve Krew
Oh, so you're slowly ruining your car.
At least with flat black you could turn it satin and clean it up smdh
#268
What? No, the plastidip peels off easily and it is a bit soft so it protects against dings too. Like when a rock hits it.
It does begin to peel however. So you peel a panel and respray. Not bad imo.
I've had two cars already tap my rear bumper and I just peeled and resprayed.
#269
It's best my car looks a bit like crap, I work in Richmond.
Anyway, Selling these, they look dope with paint. Might add gloss.
#272
#273
I am currently printing the matching dead pedal so they have the same texture. It'd printed in soft pla so it's a bit grippy, more so than the original coral piece.
#275
I had deck tape on there before, Put on after I removed the oe pedal cover thing.
I didn't like it, wore out the sole of my shoes. Plus the pedal was too small. I like these a lot. they look really nice. Perfect size and grip
