Mini me Swap help!
Mini me Swap help!
I know there faqs about this but not too sure.
-Do i need obd1 to do the d16z6 head swap?
-Do i need mpfi?
If so what do i need to complete my swap like what ecu should i run? p28?. Mine is just bone stock dpfi,d15b2.
-Do i need mpfi?
Re: Mini me Swap help!
Yes z6 are obd1 your going to need a p28 and a Jumper
Jumper/P28 combo pack -
Has the wires the come off for vtec exc. and the p28 comes with any base map you need at no extra charge. Great guys low prices I searched all over and they have the best prices and fast shipping, and they have everything in stock so the wait time will be how long it takes to get to the door.
first your going to have to do a mpfi conversion. heres a diagram
things you will need:
obd0 dizzy si or ex 88-91
obd0 ecu pm6 88-91
dizzy plugs from engine harness off 88-91 civic/crx si or ex or 90-91 integra will work
i would get it working obd0 first and make sure you dont have any cel codes.
obd0 ecu pm6 88-91
so if i wanna do the mini me swap i need to convert to obd1 and to mpfi?
so all i need is
things for the z6:
D16Z6 Cylinder Head (Including distributor cap, valve cover, plugs/wires, VTEC solenoid, etc)
D16Z6 or D16Y8 Head Gasket
P28 ECU
D16Z6 Timing Belt
things for the mpfi
mpfi intake
mpfi distributor
and a mpfi ecu
88-91 civic engine harness swap
things for the obd1
not sure what i need**
planning on doing everything at the same time. if anything is mistaken plz let me know.
so all i need is
things for the z6:
P28 ECU
D16Z6 Timing Belt
things for the mpfi
mpfi intake
mpfi distributor
and a mpfi ecu
things for the obd1
Double_Trouble_99
10-02-2009 07:01 AM
