Mini me problems Please help!!!!!!!!
#27
Re: Mini me problems Please help!!!!!!!! (Frederz)
you did do the compression test with the car at WOT right? If not then your #s will be off
#28
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frederz »</TD></TR><TR><TD CLASS="quote">only onje question comes to mind at this point in time.....How much?????</TD></TR></TABLE>
$50 shipped.. It has a few scratches on it but majority of them will be covered up when you put the cam gear bolt on..
#30
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frederz »</TD></TR><TR><TD CLASS="quote">WOT???? what is that????
and what color is the AEM camgear for sale????</TD></TR></TABLE>
WOT = Wide Open Throttle
Cam gear is red..
Cam gear is red..
#32
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frederz »</TD></TR><TR><TD CLASS="quote">so i got to let the car red line while i do a compression test?????</TD></TR></TABLE>
Yep.. Pull the spark plug wires off and put the compression tester into each plug hole and floor the car and crank it over..
There might be some other things you have to do since I have seen this done before but never did it myself..
#34
I would.. You dont want the car starting up while you doing this I dont think.. When I seen it done they just crank the car over to get a reading..
#36
ok the intake manifold that i have is a d16z6 manifold ... since i still the original SI harness what and where do i connect to the manifold?????
pictures will be greately appreciated!!!!!
#38
Err.. Dont have any diagrams.. The only electronic connections are the tps sensor, iat sensor, map sensor, eacv motor, and the injectors..
That should be it..
That should be it..
#40
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frederz »</TD></TR><TR><TD CLASS="quote">eacv are you sure ???????</TD></TR></TABLE>
Uhh.. Yeah.. I've only done it a few hundred times and rebuilt/modified many many harnesses.. The eacv is on the back of the intake right next to the throttle body..
#42
Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">have you tried this?
Thats the way my mini-me was setup.. Works great..
#43
Re: (tgreaves)
no i havent tried that what is that for, i see a plug that looks exactly just like the plug for the IAT what do i do with that plug is that the plug for the EACV???
#46
Re: (tgreaves)
ok here are some pictures of the new engine in the car, my old engine that came out, and the wiring harness that came with the new engine, i really hope that will help, and thank you .....and no is not a mpfi converted.... is a 1990 crx si
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
