map sensor code.
Old Apr 5, 2006 | 06:47 AM
Sci_v_icI's Avatar
Default map sensor code.
i am getting a map sensor code and i need to know if there is any common problems with it. its a vaccum line hooked up to a map sensor mounted on the firewall. thanks in advance for any help.
Old Apr 5, 2006 | 08:51 AM
Sci_v_icI's Avatar
Default Re: map sensor code. (Sci_v_icI)
bump i know somebodys had to have worked on a map sensor before.
Old Apr 5, 2006 | 09:03 AM
si0385.'s Avatar
as long as the vaccume line to the map sensor is not colapsed replace the map sensor
Old Apr 5, 2006 | 09:29 AM
b18_crx's Avatar
Default Re: map sensor code. (si0385.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si0385. &raquo;</TD></TR><TR><TD CLASS="quote">as long as the vaccume line to the map sensor is not colapsed replace the map sensor </TD></TR></TABLE>
make shure its calibrated........ it should turn on with a faulty map, just run like crap
Old Apr 5, 2006 | 10:11 AM
Sci_v_icI's Avatar
Default Re: map sensor code. (b18_crx)
yea it runs just real choppy like and sounds like its missing. but i can understand is that it was fine before i took the t.b. off to put that gasket on. so i should replace the map sensor??
how exactly do u calibrate it??
Old Apr 5, 2006 | 10:38 AM
b18_crx's Avatar
what code are u getting? like as in what number/flashes and what ecu/motor are u running?
Old Apr 5, 2006 | 10:44 AM
Sci_v_icI's Avatar
im getting a 5 code (map). im running a d15b7 with the stock 91 hf ecu.
snidbits
Feb 11, 2011 03:19 PM
92SikHatchBak
Engine Management and Tuning
Jan 6, 2010 09:38 PM
FSS13foxtrot
Jan 20, 2008 06:23 AM
92ehatch
16
Feb 19, 2007 11:41 PM
