Left turn signal intermittently buzzes, before working normally
Old 03-19-2019, 01:21 PM
2x0
2x0's Avatar
Default Left turn signal intermittently buzzes, before working normally
Had this problem since I got the car, just been putting it off as a minor nuisance and thinking that it would require replacing the switch or something in the column. But now I am wondering if it isn't just an electrical problem.
When I hit the left turn signal, sometimes it will just make a loud buzzing noise for a few seconds, before the turn signal actually comes on. Sometimes I have to switch it on and off a few times for it to start working. The right turn signal has always worked normally. It seems to be worse after the car sits for a while, then with more use it gets a little better.
'91 HF with a lot of hacked up wiring that I've attempted to fix.
Old 03-19-2019, 07:57 PM
Marcos Barrios's Avatar
Default Re: Left turn signal intermittently buzzes, before working normally
i had that problem last year dude but for me it only lasted about two days
then this happend
it also blew the fuse for the brake lights
luckly i had a spare tail light harness so i snipped a new socket from it
and got it hooked up to the one in the car
and so far so good ^_^
Old 03-20-2019, 03:45 AM
2x0
2x0's Avatar
Haha well mines been doing it for over two years. Think it's a short somewhere in the wiring? Or possibly the ICU?
Old 03-20-2019, 09:26 PM
i think youve just been lucky and your light bulb connector just refuses to die
try removing the bulb and putting a little grease on the contact
it might just fix the buzz
Old 03-21-2019, 03:50 AM
2x0
2x0's Avatar
So today the signal was just buzzing and buzzing until I would turn the wheel, then it would kick on. I'll make sure bulbs are good, but also thinking it might be the combination switch if that doesn't work.
Old 03-22-2019, 09:43 AM
LankorDie's Avatar
Bad turn signal flasher?
Meraut
06-23-2012 07:37 AM
ridgeline08
05-29-2011 10:38 AM
siresword
07-30-2008 08:57 PM
mr.bronx75
Lighting
01-27-2008 08:50 AM
biggentplayer
12-19-2006 10:28 AM
Quick Reply: Left turn signal intermittently buzzes, before working normally
