k20rex's crx build
#53
#54
Re: k20rex's crx build
got some nice looking wire loom and finshed up sodering and tucking my passenger side head light harness, i cut up some radiator hose and heater core hose for where it goes through, and for now it is zip tied untill i find something nice to hold the wires in place
#55
got my engine harness on also, it has stock loom on it for now, but when the funds are right i think i will be calling rywire for a mil spec, the one picture is of the clearance on the stock front cross member
#56
also i drill two holes to and got my hybrid racing shift box put in the front two bolts are the ones i drilled out, the thing looks sick and it should have enough room for big exgaust, i started putting the dash back in, the car is a slow process cause it takes alot of time and money to do it right
#58
went to the junkyard today and found a climate control, i dont think im gonna use a heater core or the controls but it was not cracked i had to buy it, i also picked up a hydro clutch parts to finsh up my hydro clutch conversion. its not done just mock up
#65
i'm a asphalt paver, lay it hot and leave it wet! i'm not rich i just work hard to slowly buy parts when i can, i started getting parts for this build over a year ago, there is not a price on my dream, i have ben thinking of build my crx like this since 2003 i love this car
#66
thanks everyone for the prop's, makes me want to get it going bad
#70
nice krx build. Do you plan on running K-tuned traction bars as well? I think you actually need em for a K swap cus the radiator needs to be relocated as well...thats what i heard
#71
i do plan on getting traction bars, and will probally get ktuned, i think i'm gonna get a eg half radiator untill i can afford to get the full sive hybrid racing one, i have the stock cross member right now but no radiator
#72
little update, got some fitting to finsh my brake line tuck, hope to have them in and get the brakes bled out this week, i also put my seats back in and dam i forgot how much i like them, i will be putting the carpet back in after brakes are bled
#74
got some work done on my brake lines, i drilled bigger holes in fire wall to get my new earls fitting in, need to get C clips for the back side of the fitting and it should hold it closer to the fire wall, i cut off the extra brake lines and flared it, its all hard lines beside 20in braided line to master cylinder, i'm waiting for banjo bolts and braided lines for all four corners, then i can bleed the brakes out, here are a few pictures
#75
just heads up, i plan on getting my car running then work out any bugs, then tear it back down for more body work, shaving the bay, cleaning everything, and finally paint
