IMPORTANT!!! 0bd0 to obd1 conversion??
Old Aug 22, 2004 | 05:01 PM
91LSVTEC HB's Avatar
Default IMPORTANT!!! 0bd0 to obd1 conversion??
i bought a conversion harness from 0bd0 to obd1. anyone have a diagram of what wires go to wat?? there are 12 wires i need to hook up. they go to vtec soleniod, bypass vavle... i need a wire diagram for this! anything will help!
Old Aug 22, 2004 | 05:11 PM
Rywire's Avatar
Default Re: IMPORTANT!!! 0bd0 to obd1 conversion?? (91LSVTEC HB)
The wires arent labled? Most conversion harnesses are different. Follow the directions
Old Aug 22, 2004 | 05:19 PM
Default Re: IMPORTANT!!! 0bd0 to obd1 conversion?? (droppedcrxsi)
i did but the wires arnt labled and the directions just say what color wire goes to wat but i dont know which wire it is under the dash you know? like uh... where the old connection is. i dont know how to explain it to well
Old Aug 22, 2004 | 06:03 PM
somebody help me out please!!
Old Aug 22, 2004 | 07:15 PM
Blown90hatcH's Avatar
Contact who you purchased it from and ask them.
Old Aug 22, 2004 | 09:43 PM
Rywire's Avatar
Default Re: IMPORTANT!!! 0bd0 to obd1 conversion?? (Blown90hatcH)
Do this...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">Contact who you purchased it from and ask them.</TD></TR></TABLE>
But if you know the color, just hook it up accordingly. I dont understand your situation I guess.
Old Aug 23, 2004 | 07:28 AM
Wes V's Avatar
Although I didn't use a "conversion harness" when I did my converstion from OBD0 to OBD1, I think I know what is causing your confusion.
The conversion loom section that goes between your OBD0 chassis loom and OBD1 computer has several wires that are "loose" due to the fact that those circuits are not part of the OBD0 chassis loom. They have to be wired directly to the component.
Wes
Old Aug 23, 2004 | 07:38 AM
AychTwenee2's Avatar
are you doing GSR?
Old Aug 23, 2004 | 07:40 AM
all you need is the wiring diagram for a p72 or whatever ecu you are running. Are you a dx or si, cause you'll have to do dx to si conversion first. I've put two H22's in 4th gens already and wired them up perfect. Distributor is the most important to get perfect, the rest is easy.
Old Aug 23, 2004 | 07:42 AM
if i knew how to read i would have seen that you are an SI and are doing an ls vtec.......my bad! Wiring is cake on that bastard!
Old Aug 23, 2004 | 03:03 PM
Default Re: (VeeTekCrx)
yeah im doin a gsr p72 ecu on a ls vtec b18b1. i am a si so... no need!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VeeTekCrx &raquo;</TD></TR><TR><TD CLASS="quote">all you need is the wiring diagram for a p72 or whatever ecu you are running. Are you a dx or si, cause you'll have to do dx to si conversion first. I've put two H22's in 4th gens already and wired them up perfect. Distributor is the most important to get perfect, the rest is easy.</TD></TR></TABLE> do u have this diagram then?? i know how to do it, i have the instructions but i dont know what color wires go to wat. the wires already in my car u know. i dont know which color is wat thats y i need a manual or something for obd0. get wat im sayin? im damn confused on this i cant even give a decent explanation. all i know is there are 12 differnt wires from the obd1 harness i need to splice 2gether w/ the obd0 wires i already have in the car. it tells me wat color wire goes to wat function but i dont know wat color wire goes to wat on the car. i dont know if that will help but worth a shot. thanks
craig88crx
Mar 16, 2010 04:36 PM
SLURS
11
Jan 23, 2009 09:17 AM
GSRinmyCRX
Jun 8, 2006 07:36 PM
burnt_rice
Jan 5, 2006 08:36 AM
EF8-Rufi
Oct 17, 2005 02:00 PM
