how to replace wheel bearing?
Old 12-12-2010, 05:37 AM
  #26
beansandrice's Avatar
Default Re: how to replace wheel bearing?
Originally Posted by bocachula_1
this thread rocks....thanks honda tech....just gotta put everything back in....xmas list; 12-20 shop press from harbor freight
Those press's work great with only one downfall... They sway a little. There is some slot at the bolted areas. I welded mine solid and I love it more. Still a great press for the money
Old 02-27-2012, 12:15 AM
  #27
nova9sw's Avatar
Very helpful topic.
Old 02-27-2012, 03:25 AM
  #28
DO IT ON ALL FOURS
OneBadTurboCRV's Avatar
Originally Posted by nova9sw
Very helpful topic.
Not exactly... People are just saying that you need a press over and over... This isn't true at all. I made a Write Up a few years ago that shows how you do NOT need a press...
http://www.ht-archive.org/showthread.php?t=2685054
Also, why bump a useless thread?
Old 04-12-2014, 06:42 AM
  #29
tonekids's Avatar
Because information goes stale. And people still need to replace their wheel bearings or remove their front hubs. I found this thread by Googling for "CRX front wheel hub removal". It is nice to be able to navigate to the info, even through "useless" threads such as this.
As an aside, your link is dead: http://www.ht-archive.org/showthread.php?t=2685054
And Willard's original apparently great writeup also seems to be missing.
Old 04-13-2014, 03:46 PM
  #30
DO IT ON ALL FOURS
You can just search my username even though it has changed. The link still works for me:
Write-Up: DIY Front Wheel Bearing Replacement
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/write-up-diy-front-wheel-bearing-replacement-2685054/
PS - The link to my thread is also at the bottom of the FAQs...
Old 03-13-2015, 05:40 AM
  #31
andresbates's Avatar
Replacing a car wheel bearing is not easy, as it requires appropriate tools and skills to do so. There are few stuffs that you will require:
• Of course a new bearing
• Jack and a pair of jack stands
• Bearing grease
• Wrench and Channel locks
• BFH and lots of rags.
• Wheel blocks and cotton pin
To know the stepwise detail of replacing car wheel bearing you can refer DIY Wheel Bearing Replacement: Removing the Old Wheel Bearing that will help you out in the right direction.
taylorjohnson11
11-14-2007 07:40 PM
low430
08-29-2005 08:32 AM
Civmochris
11-16-2003 06:13 PM
brospeed2001
08-05-2003 06:05 PM
Quick Reply: how to replace wheel bearing?
