How to remove breather chamber or pcv box
Old Jun 22, 2011 | 09:19 AM
jkwanus's Avatar
Default How to remove breather chamber or pcv box
I need to replace breather chamber because it might be clogged. Do I need to remove intake manifold first to remove breather chamber? Or can I do it under? If it is not necessary to replace, then is there any way to clean it up?
Thanks
Old Jun 22, 2011 | 09:28 AM
Tyson's Avatar
Default Re: How to remove breather chamber or pcv box
you can get to it from underneath, just like changing the oil filter.
theres a 10mm head bolt. then it just pops off the back.
youll find under the neoprene case, its just a hollow metal box. just clean it up. but i highly doubt its "clogged" or is any source any issue. if anything, the PCV valve would be clogged.
you CAN remove it and plug the hole up with a freeze plug. you really dont need the PCV system as long as you still vent the top of the valve cover.
Old Jun 22, 2011 | 02:28 PM
jkwanus's Avatar
Actually, I already replaced pcv valve due to engine vibration and leaky oil all around. after replacing pcv valve, vibration reduced but still there and leak oil almost stopped. Therefore, I checked pcv hose (im side) again, I found gunk and oil build up inside hose, so I thought pcv system (crank side) clogged in somewhere too.
I replaced due to engin vibration
spark plugs, spark plug wire, pcv valve, injectors, cleaned iacv, cleaned tb.
Also, I opened oil cap while idling. pressure comes out and oil jumped out every where. I assumed that it had problem on blow by gas.
please help.. Thanks
Old Jun 22, 2011 | 03:08 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
It helps to search once in a while...
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/help-oil-intake-2949586/
Old Jun 22, 2011 | 03:58 PM
Tyson's Avatar
sounds normal.
engine vibration? like when? idle?
Old Jun 22, 2011 | 08:27 PM
jkwanus's Avatar
sounds normal.
Yeah, it is vibrating side to side while idling at stop. My battery and radiator also vibrates. When engine is hot enough, it is more vibrating at D and R. It seems to be less at P and N gear.
I check motor mounts. However, there is no visible damage.
Actually, I am not sure which one is culprit pcv or motor mounts.
Thanks for your help.
Old Jun 22, 2011 | 09:43 PM
Tyson's Avatar
hmmm you have an auto tranny...
it just doesnt sound at all PCV related. seems like its misfiring? i would have guessed the plug wires, but youve replaced that already.
perhaps its that auto tranny... i have no clue on that stuff. but youre barking up the wrong tree with the PCV stuff.
Old Jun 23, 2011 | 03:20 AM
DO IT ON ALL FOURS
Sounds like the idle is set too low or badly in need of a tune up.
Old Jun 23, 2011 | 12:14 PM
jkwanus's Avatar
Thanks tyson.
Engine does not have misfire but just vibrates and shakes side to side. Also, trans was rebuilt last year. Only things that I didn't replace are rotor and dizzy cap.
Also, I observed once I pinched pcv hose, it took more than 6 sec to return to original shape. As I know, if I pinch pcv hose, engine idle should change at the moment. However, there is no change of idling.
Maybe I am wrong, so I need your help.
Thanks
Old Jun 23, 2011 | 12:17 PM
jkwanus's Avatar
Idle is set up arong 750rpm. Do I need to change rotor and dizzy cap? becasue I just replaced spark plugs and wires.
Thanks
Old Feb 10, 2013 | 01:25 PM
VTEC junky's Avatar
Tyson..so if i remove the pcv system on mine including the black canister and lines it will still run fine?
Rick1t
Jan 7, 2016 11:58 AM
falkenfighter
Classic Hondas
10
Jul 7, 2009 01:11 PM
jbell
Dec 31, 2004 02:19 PM
coupon
Dec 10, 2004 11:58 PM
b18bvtec4drteg
Acura TL, RL & ZDX
Mar 30, 2004 07:28 PM
