How To: Petsmart Bumpstops
Old 01-19-2008, 08:37 PM
Voodooboy520's Avatar
Default How To: Petsmart Bumpstops
Bumpstops from Honda: $20 each
Autozone bumpstops: Non exsistant
Petsmart bumpstops: $12/4
While putting my Koni\GC's on I noticed my stock bumpstops crumbled and fell away, most likely from the track events I drove on stock suspension. When I considered my options I decided a little creativity was in order, so after brainstorming with a friend we came up with dog chews. One trip to Petsmart later, I had these:
They feel identical to bumpstop material, and are the right dimentions. First, I clipped 1" pieces off the ends. I found it easier to drill a hole, and then use heavy wire cutters to cut around:
Cut to about 1":
I used a 1/2" drill bit to ream it out maybe 1/16". In order to effectively ream with a drill bit that was too small, I made the hole smaller:
After that, they should fit on the shock shaft:
And just for fun:
So there you go, all new bumpstops for $12. I was also considering filling dixie cups with window weld, but it would have taken too long to cure and I'm not sure the longevity of poly.
Old 01-19-2008, 08:39 PM
GSX 4G63T's Avatar
Amazing, I always went to oem. but hey looks great,
Old 01-19-2008, 08:43 PM
D50boy's Avatar
Default Re: How To: Petsmart Bumpstops (Voodooboy520)
Very resourceful.
Lube it up with the peanut butter paste
Old 01-20-2008, 06:51 AM
drdisco69's Avatar
OMG u so smart u should be a injyneer!
Old 01-20-2008, 07:10 AM
ProMotive's Avatar
Default Re: How To: Petsmart Bumpstops (drdisco69)
Wow, never thought of that
Old 01-20-2008, 07:22 AM
Tippyman's Avatar
Default Re: How To: Petsmart Bumpstops (ProMotiveConcepts)
Innovative!
Old 01-20-2008, 07:26 AM
Boosted Chemist's Avatar
Default Re: How To: Petsmart Bumpstops (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Innovative! </TD></TR></TABLE>
Right on I bet they are much stronger and will last longer too.
Old 01-20-2008, 07:36 AM
defnu's Avatar
update when or if worn out / bumpstop life...great brainstorming though!
Old 01-20-2008, 07:39 AM
Crx Jimmy's Avatar
You can also use the rubber(or poly) from swaybar endlinks from a big american car. They are really cheap at autozone.
Old 01-20-2008, 08:52 AM
Default Re: How To: Petsmart Bumpstops (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">You can also use the rubber(or poly) from swaybar endlinks from a big american car. They are really cheap at autozone.</TD></TR></TABLE>
Thats a good idea too, probably would fit a little better
I drove it around a little last night and today and because i forgot to tighten the set screw on the spring perch, I was slammed There is a very good chance I was on the bumpstops because they were pushed all the way up, and they're still all there. So far they're holding up. I just wish I could get my front to raise up a little more, I'm going for a stock ride height and I'm having to compress the spring with he pearch to get it to go anyhigher.
Old 01-20-2008, 11:11 AM
CRX Toad's Avatar
Default Re: How To: Petsmart Bumpstops (V-MONSTER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">OMG u so smart u should be a injyneer! </TD></TR></TABLE>
WAY TO GO V-MONSTER!!!!
Old 01-20-2008, 12:44 PM
GSX 4G63T's Avatar
i got those and after 6 months they wore away
Old 01-20-2008, 01:19 PM
harmonator84's Avatar
Default Re: How To: Petsmart Bumpstops (4163175587)
nice
Old 01-20-2008, 04:00 PM
I CRX I's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voodooboy520 &raquo;</TD></TR><TR><TD CLASS="quote">Bumpstops from Honda: $20 each
Cut to about 1":
And just for fun:
</TD></TR></TABLE>hahaha thats genius! if i were you, i would look for the black rubber that kong sells. i think its the strongest of all the materials they use and i can vouche for that!! my 75 lbs pitt was able to chew any damn toy i threw at him and some dry wall, carpet, jeans, and even metal. but i bought a kong ball (the black one) and that thing never even dimpled! lasted long enough for me to lose it.
EDIT: how about using four of these?? http://www.doggy-gifts.com/s.nl/it.A/id.2697/.f
Old 01-20-2008, 07:37 PM
doublethink's Avatar
haha nice!!!
Old 01-22-2008, 07:20 AM
Default Re: How To: Petsmart Bumpstops (I CRX I)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I CRX I &raquo;</TD></TR><TR><TD CLASS="quote">hahaha thats genius! if i were you, i would look for the black rubber that kong sells. i think its the strongest of all the materials they use and i can vouche for that!! my 75 lbs pitt was able to chew any damn toy i threw at him and some dry wall, carpet, jeans, and even metal. but i bought a kong ball (the black one) and that thing never even dimpled! lasted long enough for me to lose it.
EDIT: how about using four of these?? http://www.doggy-gifts.com/s.nl/it.A/id.2697/.f</TD></TR></TABLE>
I saw those, but they were like $10/each. Plus the rubber was like indestructable, and I figured you wanted bumpstops to give some.
Old 02-16-2008, 01:25 AM
aimbot's Avatar
i hope my dog doesnt mind me taking his toy away.. lol.
Old 03-06-2008, 04:08 PM
Quick update: after almost 3 hours on track, bumpstops are still intact.
Old 03-06-2008, 04:47 PM
Tippyman's Avatar
Default Re: (Voodooboy520)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voodooboy520 &raquo;</TD></TR><TR><TD CLASS="quote">Quick update: after almost 3 hours on track, bumpstops are still intact.</TD></TR></TABLE>
Awesome.
Honda boys at their best.
Old 03-06-2008, 06:02 PM
sgallagher's Avatar
Default Re: (Tippyman)
silly dogs toys are for cars.....?
Old 03-06-2008, 08:19 PM
OF THE KINGS
x4thGenCafe's Avatar
nooiiicceee
Old 03-24-2008, 08:20 AM
vartz04's Avatar
Default Re: (x4thGenCafe)
whats with that picture of "bushings", good idea tho using the pet toy
Old 03-24-2008, 08:31 AM
EL Vap133's Avatar
Default Re: (vartz04)
Very good stuff, thanks for the input!
Old 03-24-2008, 08:46 AM
zccr-xsi's Avatar
damn i know where in getting my new bumpstops from.this should be stickied in the ef faq
Old 03-24-2008, 11:51 AM
vartz04's Avatar
yeah i guess you shouldn't get those sway bar bushings, someone said they turned retarded after 6 months of using them
Quick Reply: How To: Petsmart Bumpstops
