How to fix my ebrake help
Old 05-08-2006, 01:57 PM
I Like Hondas's Avatar
Default How to fix my ebrake help
I just bought my crx and the e brake doesnt work. How do i fix this?
Old 05-08-2006, 02:01 PM
looxs's Avatar
Default Re: How to fix my ebrake help (I Like Hondas)
you can remove the center console and tighten that nut. It could also be that you have bad brake shoes ( if you have drums in the rear) you should swap those out and then tighten the adjustment screw on the drums when your finished.
Old 05-08-2006, 02:02 PM
The guy already did a rear brake conversion.
Old 05-09-2006, 12:44 AM
8atman's Avatar
Default Re: (I Like Hondas)
so he did a disc conversion? Check the line mabie that guy fucked up the line or mabie didnt set it up right, if so check the break line, make sure it is attached, other then that just inspect everything. Is there any slack or any give at all? Your breaks are the most important part of a car expletive a motor if you cant stop. Good luck and post if you need help still
Old 05-09-2006, 04:52 PM
Thanks a lot, I havent had time to check it. But I will get back to you.
Old 05-09-2006, 07:06 PM
8atman's Avatar
no prob get back to us if you figure it out or need more help
shelltodreamda9
05-18-2011 03:09 PM
gilbert90605
10
10-24-2009 02:19 PM
opera936
12
05-17-2007 10:33 AM
Psionic
03-18-2006 09:41 AM
scoobyghost
06-02-2003 11:29 AM
Quick Reply: How to fix my ebrake help
