High impedance injector for d16a9
I want to remove the low impedance injectors (with resistance box) I want to put high impedance and I take off The Resistance Box it Is for a d16a9 engine but I do not know which reference to look for.. Any advice?
Im thinking to obd1
Thanks
Im thinking to obd1
Thanks
Re: High impedance injector for d16a9
Assuming the D16A9 uses the same injector as the A6 (235cc), then an injector from the next generation Civic (92-95) has the same output, and the injector in the D16Y8 from 96-00 is nearly the same (240cc). The D16Y7 injector is lower (180cc), that one would not be ideal.
http://www.phearable.net/information...ctorsizes.html
Ok Thanks i will check them
do you know where i can buy a Fuel Injector connector im loking for ebay amazon but the obd1 that i see on picture its obd0
thanks again
thanks again
