HELP Please First gen b16a trans b16a3 axles "what seals?
Help turbo pistons tune ect coming soon rn I have a first gen b16a cable trans with 95 delsol dohc vtec axles and half shaft I tore a seal changing trans and need to know which axle seals to buy possibly a part no. Can't remember what seals I had before it's been a while since then thx
Re: HELP Please First gen b16a trans b16a3 axles "what seals?
I just wonder because the b16a3 originally had a hydro tranny idk if the of of the seal would be the same
Correction not of , od as in outside diameter thanks b16a3 is the 95 dohc del Sol engine trans was hydrolic
the driver's side seal you need is determined by the intermediate shaft - the passenger side seals are all the same 90 and up - if you have the intermediate shaft with male end where the axle goes on, you need 94 and up seal - if it has female end, you need 90-93 seal
ckirso
10-29-2012 12:02 AM
90ED6LSV
Transmission & Drivetrain
11-03-2011 07:27 PM
