Help On my driver side. VIBRATING AND SHAKING
OF THE KINGS
I tried searching what could be wrong with my car and I think it might be my wheel bearing but i really dont know for sure.
I just swapped my hatch and my front left side shakes and vibrites when i give it gas. It makes noises sometimes when i turn with the gas.
I jacked my car up and tried shaking the wheel back and forth and there was no play. One of my friends said if there was it would have been my tie rod or whatever . . idk
If you might know whats up you should let me know so i can get it fixed
Thanks
Thanks
Location: Where the wild things are in, NY, United States of America
1 Post
your right one as in your passengers side? and the vibration is coming from the drivers? 90% sure this is your axle but hey...
to check for a bad wheel bearing, i always move the wheel (unloaded off the ground) back and forth on the vertical axis to see if theres any axial play. thats a bad sign if theres any movement.
OF THE KINGS
Re: (ComeOnKip)
i checked for play and there wasnt any.
and my axle looks fine.
it vibrates bad when i give it gas. especially when im in like 4th or 5th in a lower rpm
Re: (ComeOnKip)
you can tighten down a tie rod end all day, the ball joint could still be bad in it though, I would pop it off the knuckle and see how much play you have in it, or the ball joints in one of the knuckles could be bad too causing vibration, seperated tire possibly. The axle you didnt change could be going bad.
