HELP (CAN I USE A CIVIC 92 MPFI)
Re: HELP (CAN I USE A CIVIC 92 MPFI)
use a mpfi what? there are many components you can use. i assume you mean the intake manifold though, in which case yes you can use that to do the dpfi to mpfi conversion.
http://hondaswap.com/swap-articles/d...writeup-49557/
you can use the newer distributor, but only if the ecu is also obd1.
since you are just converting to mpfi at this point i imagine you are not trying to convert to obd1 as well. that being said, you will need to get an obd0 mpfi distributor.
THANKS THAT HELPED ALOT. I THINK I FOUND MY PROBLEM. I DID EVERYTHING BUT THE CAR WONT START. IM CURRENTLY TRYING TO USE THE OBD1 DISTRIBUTOR.
yeah you can't mix obd0 and obd1 parts. you have to use the full on obd0 ecu and dizzy or the obd1 ecu and dizzy together, no mixing and matching.
89hatcher
06-05-2006 02:01 AM
