headgasket????
headgasket????
ok so started the old crx up and started burning mass oil and did the smoke screen and even had beads of oil in tailpipe. went out got a compession tester and here what i did 1. took all spark plugs and plug wires out of hole 2. pluged tester into each hole from 1-4 and every time i started id hold gas pedal down at WOT and let it off when i got out to check it, i only cranked the car 4-5 times as the instructions said to crank the car for the number of cylinder it had. numbers were 165, 160, 157, 173 was i not cranking long enough????
wtf could this be\
thank you
wtf could this be\
thank you
