which head gasket to use on a JDM B20b with P8R head
Old 08-06-2012, 08:20 AM
90civic-ZC's Avatar
Default which head gasket to use on a JDM B20b with P8R head
I've gotten conflicting answers in my search...... My B20b is the high compression with a P75 LS head but I have a P8R head I want to throw on it but unsure if I need a one layer or multi layer head gasket and which do I order for, the P8R head or the block?
Old 08-06-2012, 02:18 PM
stucat's Avatar
Default Re: which head gasket to use on a JDM B20b with P8R head
Just get the b20 head gasket and then enlarge the dowel holes to fit.
Old 08-07-2012, 11:28 AM
90civic-ZC's Avatar
Anyone else have anymore info or comment on what he said?
Old 10-16-2012, 01:12 PM
darnizzle8805's Avatar
The P8R comes from the factory with a 2 layer head gasket. Installing the P8R will lower your compression ratio unless you have had it milled. But just order Stock 3 layer gasket and you will be fine
Old 10-22-2012, 05:23 AM
90civic-ZC's Avatar
See I've thought about that, but didn't know if it would lower the compression. Do you know how much I should shave the head to get it back to the 9:5-9:6 CR?
Old 10-22-2012, 02:55 PM
According to www.zealautowerks.com .045" assuming that you have b20b pistons still. I dont know all of your details so go to that site and playaround with the specs and see what you come up with
Old 10-22-2012, 03:44 PM
alex14's Avatar
So you have a b20 block, and you have a b20 head, and your asking what gasket you need?
Old 10-29-2012, 04:54 AM
90civic-ZC's Avatar
Yes, for a low compression B20 P8R head......bigger (vtec) intake valves and bigger combustion chamber. So yes I curious about which head gasket to use, either for the head or buy it for the block. Darnizzle, thanks for the help.....because my friend gave me that head and I would really like to use it. My first build where I'll be swapping heads.
Old 10-31-2012, 06:15 PM
No problem, I try not to be an immature *** like some forum members.
God-Driven
02-06-2008 05:35 PM
motormike40
04-01-2007 08:14 PM
eats06702
03-14-2007 09:22 AM
2ndgentegracer
10-09-2006 07:24 PM
Quick Reply: which head gasket to use on a JDM B20b with P8R head
