For guys that have indiglos on their EF, need help.
I already have them all installed, I just need to know what wire to connect the hot wire to. I want to have it work with the regular lights, just like normal as far as when it turns on.
Any help as to exactly which wire (color/location) would be greatly appreciated!!
New User
Re: For guys that have indiglos on their EF, need help. (TypeR0207)
look at the top of the fuse box under the dash and their is two empty slots get a female connector and plug itinto the slot on the right that is a secondary parking light output make sure you fuse the wire and never wrap a wire around a fuse and shove it back into teh panel it can cause a fire
I wired mine up to the light on the cigarrette lighter...probably not the best place, but its easy and doesnt require any thought
Re: For guys that have indiglos on their EF, need help. (marked001)
i just wired it to the back of the guage cluster. where those + and - signs are. they come on when ever the car is started but oh well. makes wiring easy.
Re: For guys that have indiglos on their EF, need help. (CR-X)
All good stuff .....
But I just got a buzzer for the lights (buzzes when they are on with the car off) and it is wired into the #2 and #3 accessory clips ........
And my POS doesn't have a cigarette lighter ......
Guess I'll just do it to the "+" lead on the back of the gauges unless there is another way you can think of.
Wire it in to the dimmer switch. Thats the easiest way possible. Hot wire goes to the solid red wire, ground it on the black on. Dont worry about the other half red/black wire. Have fun
Jonathan_ED3
09-05-2002 10:12 AM
