Gas tank swap?
Old 08-31-2010, 09:23 PM
Danthemagicbum's Avatar
Default Gas tank swap?
The fuel pump is in the tank and you have to pull the tank to replace the pump as far as I understand. So has anyone ever swapped in an EG or EK tank so they can replace from the top?
Old 09-01-2010, 10:41 AM
pimpwagon's Avatar
Default Re: Gas tank swap?
Dropping the tank isn't hard. Besides, once you put a new fuel pump in, you shouldn't need another for a long time. why complicate things?
Old 09-01-2010, 06:10 PM
mattliston's Avatar
x2, why make it hard
who gives a **** if it takes you an extra 15 minutes to change a fuel pump?
Old 09-01-2010, 09:21 PM
hatchet_honda's Avatar
wellll...the tank isnt the reason you can change it from the top on an eg. the eg has a hole in the chassis to access the pump. ef not so much. anyone else agree? or am i crazy..
Old 09-01-2010, 09:25 PM
mattliston's Avatar
honda made it easier in 92 for civics
88-91 has an inspection palte, that is about it
Old 09-01-2010, 09:35 PM
exactly. you can see the pump kinda buut cant really access it from top on the ef. eg has a hole there to do just that. remove the pump. i love seeing ppl trying to remove the tank on an eg to change the pump lol when will they learn..even seen a 4dr in a shop with the tank down. 427 bucks wasted!
Old 09-29-2014, 11:59 AM
ef2_civic's Avatar
so does anyone know if u can swap out a ef tank for a eg/ek. I need it more because of fuel stravtion reasons on the track? and yes I know FCS makes a fuel cell but $500 for it ouch!!!
Old 09-29-2014, 04:01 PM
mattliston's Avatar
Remove the fuel tank, air it out and make sure all fuel is out and vapors gone, then have a proper welder cut the bottom of the tank, and weld in a few baffles. There are baffles in there from the factory, but the ones around the fuel sock area are a bit shorter then they could be.
In all honesty, if you are getting starvation, its a good idea to yank the fuel sock out for an inspection and see if its clogged up. I didnt have issues in a few of my EF/ED cars with very stiff suspension and grippy tires.
danno33
04-16-2011 09:23 AM
TeggieeTuner
11-18-2010 10:32 PM
uberEFtuner
05-23-2010 10:59 AM
kaoss_11
11
12-09-2004 08:29 PM
digitalspice
10-02-2001 02:29 PM
Quick Reply: Gas tank swap?
