Flooded Car
Re: Flooded Car
Please don't write off your CRX/Civic. Really hate seeing these things in the junkyard.
Touching My Member
Re: Flooded Car
You may get lucky, I had a Cowl leak years ago that left my Civic with a good inch or two of water. I removed everything, dried it all, applied CRC Di-Electric grease to all of the connectors, and it all turned out fine. My ECU was mounted up high, under the dash, so it didn't come into contact with water.
Re: Flooded Car
If he hasn't gotten to it yet, the damage is most likely significant enough that new wiring will have to be (or definitely should have to be) replaced, new rust or accelerated previously existing rust will take over, etc. I went through Hurricane Andrew in 92 in New Orleans with my CRX, and luckily I was in one of the few high areas and the car was unaffected, but peoples' cars kept having issues for long after the storm with sudden loss of power or battery drains. And Andrew was a little bitch compared to this. My best advice would be to take the insurance money and run or take the money, and buy back the car with the understanding that it's a shell at this point and anything else that is salvageable is lagniappe.
Re: Flooded Car
Insurance values these at like 300 bucks.
There is NO replacement for a CRX.
Do not even contact insurance.
Take carpet out.
All connectors, spray Water Displacer 40 (wd-40) at the ends of the connectors and where the wires enter the terminals. Then, before you plug the connectors back in, use Dielectric grease liberally.
Carpet, either power wash and let dry in sun, or replace it with new carpet.
Might not hurt to spray some Rustoleum on your seat tracks, the mounting bolt heads etc. Use Anti-Seize on all the bolts and screws as you fasten stuff back up.
Good luck. These cars are small/tiny. Means cleaning it inside is pretty simple since it is not very large to clean. Also, manual windows, manual locks, etc, not much electrical to go wrong on it. Not like a new car with all the gadgets that will fail and short out.
g2tegsown
07-12-2005 03:36 AM
paulzy
06-27-2002 10:37 AM
