Factory Alarm on 91 dx? odd starting problem
Old 03-13-2011, 07:07 PM
nicefighter80's Avatar
Default Factory Alarm on 91 dx? odd starting problem
Its a 91 civic dx, automatic, the battery has died for some reason and when I put it on the charger and try to start it, it cranks a few times and clicks ( I know this is a sign of a bad battery) but then the turn signals flash on and off and this little red light on the dash blinks, and this happens when the key is off.
What could be the problem, is there and alarm causing the blinking when the battery is low?
Old 03-13-2011, 07:14 PM
Crazy Honda Guy
Deetz's Avatar
Default Re: Factory Alarm on 91 dx? odd starting problem
There is no factory alarm for that car.
The problem you describe sounds like one i had a few years ago with a crx. It ended up being that both the main battery cables were all full of corrosion making for a bad connection and ground. I had the signals flickering too.
Anyway, i replaced the cables, car started right up and problem solved
Old 03-13-2011, 07:17 PM
Ok, I'll give that a hot, it's just that little light looks like a alarm light, and under the dash is a black box that looks like an alarm module and it says "made in usa" on the box
Old 03-13-2011, 07:24 PM
Crazy Honda Guy
Deetz's Avatar
if you have a black box like that, something has been added to your car at some point
Old 03-13-2011, 07:31 PM
Yea, but iv'e seen this light or other ef's? its on the lower left of the dash, like in one of the block off plugs on the dash. So i'll try the terminal cleaning tomorrow.
Old 03-13-2011, 10:48 PM
Nooch's Avatar
post a picture?
Old 03-14-2011, 06:57 AM
hatchet_honda's Avatar
if your seeing an led indicator light (like used for alarms) then someones added that to the car. seeing it on other cars its possible someone else had an alarm put on their car and they installed their led in ther same spot, its a common area for that light to be.
Old 03-14-2011, 09:25 AM
ThatRicerDaniel's Avatar
Just unplug the aftermarket alarm "black box". If you dont have a remote it wont matter. Worst come to worse you will have to bypass the alarm.
98civdx
Audio / Security / Video
04-15-2010 06:33 PM
Midgetmax4
03-31-2007 06:27 AM
CIVIC96DXcp
04-10-2005 05:00 PM
95CivicConv
01-12-2005 06:31 PM
smlyjo
Acura TL, RL & ZDX
11-06-2002 09:17 PM
Quick Reply: Factory Alarm on 91 dx? odd starting problem
