b17 wont start after tryed removing vafc2? need help
i got a pr3 in my crx i tryed removing the vafc2 made by apexi and it wouldnt start so i hooked it back up and still wouldnt start then it threw a code 15 "Ignition Output Signal missing or defective ignition output signal " any ideas i need my car back so i can get to and from work ... it cranks over just wont run ,
DO IT ON ALL FOURS
Re: b17 wont start after tryed removing vafc2? need help
A PR3 is a B16A...
How exactly did you go about removing the VAFC? Sounds like you went at it like a stereo thief...
i toke and cut the 4 wires they and connected the wires they cut to put the vtec controller back together like it said . then i cut to power wire. leaving the rpm "which is just tapped into the rpm sensor in there and the grounds in there. tryed to start it and nothing. so i connect the wires just how they were befor i cut them and tryed starting it again and again nothing happend .it cranks just not getting spark gets gas i can smell it when it is cranking over.
