doing a d15b swap in my car, using si tranny, need answer real fast
Old 06-12-2004, 07:39 PM
Gant's Avatar
Default doing a d15b swap in my car, using si tranny, need answer real fast
i have a 90 standrad hatchback
i ONLY use a 89-91 si tranny for axles to fit in correct?
Old 06-12-2004, 07:46 PM
mr. carpenter's Avatar
Default Re: doing a d15b swap in my car, using si tranny, need answer real fast (Ba4)
i believe so. anyone confirm? i'm running a 91 si tranny with the old axles from my std.
Old 06-12-2004, 07:52 PM
Gant's Avatar
Default Re: doing a d15b swap in my car, using si tranny, need answer real fast (mr. carpenter)
how can u tell what year the Si trans is to? thank you for any help
Old 06-12-2004, 07:57 PM
i just know what car it came from. the tranny year does'nt matter but the clutches are different from 88 to 89 i think?
Old 06-12-2004, 08:07 PM
Gant's Avatar
hmmm did some seraching
is it true i can use any year si CABLE tranny and it will fit into my axles?
i belive 88 has differnt spline count on input shaft whereelse 89-91 are all the same
since im dropping in a d15b can i leave the d15's flywheel in and bolt on the si tranny?
Old 06-12-2004, 08:46 PM
Gant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 &raquo;</TD></TR><TR><TD CLASS="quote">hmmm did some seraching
since im dropping in a d15b can i leave the d15's flywheel in and bolt on the si tranny?</TD></TR></TABLE>
TTT
Old 06-12-2004, 09:00 PM
91civicDXdude's Avatar
All L3 trannies are compatible with all 88-91 axles.
The difference lies in the outer hub splines. i.e., if you use STD/HF hubs, you must use STD/HF axles, but any transmission will work.
Old 06-12-2004, 09:35 PM
Gant's Avatar
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">All L3 trannies are compatible with all 88-91 axles.
The difference lies in the outer hub splines. i.e., if you use STD/HF hubs, you must use STD/HF axles, but any transmission will work.</TD></TR></TABLE>
thanx for ur reply, u dont know how many ppl are so misinformed, me/friend have bought parts from many d series ppl and when my friend would bring up the subject of NO you dont have to change ur hubs when putting in a si tranny into ur dx/hf/standard everyone would tell us "ur tripping u have to chagne ur hubs" thanx for ur reply just needed confirmation
extensioncordy
22
09-22-2006 03:18 AM
pinecone
05-20-2006 11:02 AM
LurkerS8
17
06-25-2005 07:46 AM
93eg-EKhybrid
01-26-2003 06:42 AM
Nossy
04-10-2002 10:33 PM
Quick Reply: doing a d15b swap in my car, using si tranny, need answer real fast
