DIY CRX race harness, with questions and Pinout
Old Jan 24, 2011 | 04:15 AM
ub3rn00ber's Avatar
Default DIY CRX race harness, with questions and Pinout
Heres the deal, i really want to get my car running. If i make a harness my self for i think ill have enough $ to get the car done. Since its a race car, i want the minimum. No alt, speedo, ps, ac, no factory dash guagues, no lights.
Few questions:
1) Is heat shinking wire what constitutes sheilding?
2) Will 16 guage wire for everything work? Or do i need to use 18ga for everything and 14ga for the dist?
3) Im not sure about these, do i need all of them? if so what do they do and hook up to?
B13 - top dead center p
B14 - Top dead center m
D10 - Electric Load Detector
D16 - laf
The Following is what i think i need, if anyone sees any i need/dont need please let me know, so i get it right
A1 - Injector 1
A3 - Injector 2
A5 - Injector 3
A2 - Injector 4
A4 - vTECH solenoid (is this the green wire on the other cam shaft - ie next to the distribitor?)
A9 - Idle air controle
A11 - EGR Controle
A21 - Ignition unit signal
A22 ignition unit
A24 - Ground
A26 - Ground
B2 - Ground
D3 - Knock sensor
D6 - vtech Pressure Switch (the switch in the block below the intake, on the cam gear side?)
D8 - Air flow sensor
D11 - Tps
D12 - EGR
D14 - o2
d15 - Intake air temp
d16 - laf
d17 - map
d19 - map sensor
d20 - tps
d21 - ground
d22 - ground
Heres the ECU pinouts for what im talking about.
Old Jan 24, 2011 | 04:32 AM
Jenkinsal2's Avatar
Default Re: DIY CRX race harness, with questions and Pinout
I am not attempting to be rude, so do not take this the wrong way but you really have no clue what you are getting yourself into. I say this because I am currently working on the same thing and it is much more involved and expensive than it sounds. I would reccomend you either strip the wiring from your stock harness If you can correctly understand the wiring diagram, or you can purchase a Universal Painless type harness and wire it via the instructions.
Old Jan 24, 2011 | 05:52 AM
crx_si-r's Avatar
if you havent built a harness before, you might get a lil overwhelmed. just so you know 14g and 16g wire are too thick for the harness. oem harness are made with either 18-22g wiring. be patient and dont rush it, otherwise you will get frustrated.
if you like i can build one for you, pm i sell these all the time.
Old Jan 24, 2011 | 05:59 AM
crx_si-r's Avatar
oh, and to answer your question about "shielded," NO. adding heat shrink to a wire does not make it shielded. the following makes a shielded wire:
primary wire, covered by a layer of vinyl. the covered wires are then wrapped by strands of wire, which is then covered by another layer of vinyl protection. the stranded wire is then grounded. this purpose of this is to keep any magnetic/static interference from affecting the reading of certain sensors.
its possible that the harness will work without the shielded wire, but you chance tripping a CEL without the shielding. when i make a harness i use all new shielded wire. the following use shielded wire:
-crank position sensor
-cylinder position sensor
-TDC
-knock sensor
-o2 sensor signal wire
pm me if you would like to purchase a harness from me, or need help.
Old Jan 24, 2011 | 06:20 AM
efjones9's Avatar
Took apart my spare cabin harness today and daam its a lot of wires. So I went to my mentors race shop and he said its a lot easier to start from scratch and throw all the oem wiring out. So id suggest getting a helms manual, read up how to solder heatshrink and the basics of hiw eletricty works and start from there. I have my old uti book tht I could scan to help u if ya want to learn more about electricity n stuf. Good luck
Old Jan 24, 2011 | 07:24 AM
ub3rn00ber's Avatar
Thank you for the answer on sheilded wire, that was exactly what i was looking for. Where do you buy your wire, everything im finding is really expensive cause you have to buy in bulk.
If i wanted to use new sensor plugs to connect everything, where would i be able to buy the right ones?
Old Jan 24, 2011 | 08:05 AM
Jenkinsal2's Avatar
Finding new plugs entails a lot of digging. The majority of harness makers wash and reuse the plugs and crimp on new pins. I would advise you do alot more research before moving any further. The tooling alone to make a single harness far outweighs the price to just buy one premade.
Old Jan 24, 2011 | 08:23 AM
xXxRed FoxXx's Avatar
Great advise so far...
and check this out...Official Road Race ELECTRICAL THREAD
it'll give you a clue where to source the materials and some ideas.
https://honda-tech.com/forums/road-racing-autocross-time-attack-19/official-road-race-electrical-thread-info-questions-builds-only-2771547/
Old Jan 24, 2011 | 09:28 AM
efjones9's Avatar
just get a obd1 engine harness from a junk yard
Old Jan 24, 2011 | 09:30 AM
efjones9's Avatar
https://honda-tech.com/forums/showthread.php?t=2771547
good info!
Old Jan 24, 2011 | 10:17 AM
crx_si-r's Avatar
I buy the shielded wire locally per foot. The pins and weather pack boots I order take atleast a week to come in so I order in advance, I order bulk amounts in advance so I don't run out. Lmk if you would like 1 built I have enough to build 3 harnesses right now.
Old Jan 26, 2011 | 10:21 AM
ub3rn00ber's Avatar
http://cgi.ebay.com/ebaymotors/Rywir...fAudioQ5fVideo
i know this i a d, but wouldnt it be pretty close to what i need?
Old Jan 26, 2011 | 11:26 AM
Jenkinsal2's Avatar
yes That would essentially be what you need and would save you a vast amount of headache and money in the end.
Old Jan 26, 2011 | 01:23 PM
crx_si-r's Avatar
Good luck on the auction, I'm pretty sure it's reserve price will be close to the buy it now. Not trying to sound rude, giving my honest opinion.
Old Jan 26, 2011 | 01:35 PM
ub3rn00ber's Avatar
i might by now i just sold a motor
Old Jan 27, 2011 | 03:47 AM
ub3rn00ber's Avatar
So how close is the b and d? is it just the ecu plugs that are different?
Old Jan 27, 2011 | 04:06 AM
Jenkinsal2's Avatar
You cannot use a B-series Harness.
Old Jan 27, 2011 | 04:12 AM
ub3rn00ber's Avatar
i didnt think it would work
bee015
Sep 28, 2010 06:31 AM
Power Rev Racing
Jan 9, 2006 07:12 PM
Beau Gotti
Dec 2, 2004 09:08 AM
WhiteTegSE
Apr 21, 2004 12:12 PM
