differences in crx model
Old 07-19-2003, 09:45 PM
TylerB's Avatar
Default differences in crx model
got a couple of questions b4 i buy...
1. any major differences in weight between models?
2. do 88-91 have different bodystyles?
3. i heard hf is the best for track *****...true?
thanks
Old 07-19-2003, 09:48 PM
Hondasaurs's Avatar
Default Re: differences in crx model (94prelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94prelude &raquo;</TD></TR><TR><TD CLASS="quote">got a couple of questions b4 i buy...
thanks
1: I've seen the wieght vary tremendously.....easiest way..
HF= lightest
DX= more heavy
Si= heaviest
2: The front bumpers are from 88-89 are the same 90-91 are different
3: True...it's the lightest
Old 07-19-2003, 11:18 PM
B2FiNiTY's Avatar
88-89 have different taillights from 90-91.
Interior changes. Exterior changes. Nothing dramatic.
90-91 Si have disc brakes all around.
Old 07-19-2003, 11:42 PM
Goldfingiz's Avatar
SI = sunroof
Old 07-20-2003, 01:36 AM
SIRX's Avatar
Default Re: differences in crx model (Goldfingiz)
Your search for crx differences returned the following 14 results.
that was in the archived section. try recent topics also
Old 07-20-2003, 02:27 AM
crx_4_style's Avatar
Differences Between the 2nd generation CRX-es.
ยป 88-89 CRX's don't have side impact beams in the doors, the 90-91 do.
ยป All CRX's have rear drum brakes except the 90-91 Si's
ยป 90-91 have a round instrument gauge cover while the 88-89 one is more squarish.
ยป 88-89 door moldings are taller and flatter, the 90-91 ones are shorter but stick out further and have a beveled edge to them.
ยป 90-91 rear lights have a 1/2 inch black edge all the way around them, the 88-89 do not.
ยป 90-91 have have fake air ducts molded into the bumper.
ยป 88-89 have slightly different front and rear bumpers than the 90-91.
ยป 90-91 bumper mounted turn signals are clear with amber inserts in them, the 88-89 lenses are just solid amber and shorter in length.
ยป 88-89 Corner mounted parking lights have their mounting screws visible while the 90-91 ones are attached by hiden screws.
ยป 91 and perhaps 90 headlights have a vent in them to help prevent moisture buildup.
ยป 90-91's are the heaviest, the 89 is lighter, and the 88 is the lightest. In each year the hf is the lighter model, then the DX and finally the Si weighs in at the most.
ยป 88 manual transmissions have an input shaft with 21 slpines.
ยป 88 has a 21 spline input shaft, the 89-91's have a 20 spline shaft.
ยป 90-91 clutch is 212mm, the 89 is 200mm and the 88 has either a 200 or 190mm.
ยป 88 does not have a clutch safety switch. Which means it will start without having to press the clutch in.
ยป 88-89 Si models have 105hp, the 90-91's have 108hp due to different ecu settings and possibly a slightly different cam.
ยป 88's have pillar mounted seatbelts,90-91 have door mounted belts, 89 si's and dx's have door mounted belts, 89 hf's have pillar mounted belts.
ยป Models with door mounted belts have a wider pillar at the end of the door to accomodate the belt mount, this also means that the glass is and inch or so shorter.
ยป 90-91's have a red seatbelt warning light built into the dome light.
ยป 88's have what Honda called "passive rear steering" which makes them slightly more agile but some owners complained that they didn't like the "twitchiness" feeling of it so it only existed the one year.
ยป Rear lower control arms changed between the 88 and 91 years and the rear shocks have different mounting points.
ยป 88 has slightly different sized front shocks.
ยป 88 ecu has a different internal design than the 89-91 but the inputs and outputs are the same and ecu's can be swapped between years.
ยป 88-89's have the hazard light switch on the top of the steering column, 90-91's have it mounted on the dash.
ยป 88-89 Si seats have a white pinstrip, 90-91 Si seats have a red pinstrip.
ยป 88 has a pocket at the bottom of the drivers door.
ยป 90-91 Si's and perhaps the 89 Si have a mesh pocket on the back of the seats.
ยป 88 cam indexing is the same for all the engines, 89-91 si's have indexing that is different from the other engines.
ยป 90-91 and possibly the 89 have larger reverse lights that are set further to the sides than the 88.
ALL THE CHANGES EVERY MADE BETWEEN THE 2ND GENS
Old 07-20-2003, 08:52 AM
TylerB's Avatar
Default Re: (crx_4_style)
so best looking trach ***** would be 91 hf? are the hf the cheapest?
Old 07-20-2003, 07:04 PM
TylerB's Avatar
Default Re: (94prelude)
bump...
Old 07-21-2003, 07:14 PM
TylerB's Avatar
so, 88-91 have basically the same style? and whats a terd and a rex? isnt rex a 87-below crx?
Old 07-21-2003, 09:16 PM
No tears. Only dreams, now.
VashTheStampede's Avatar
the 88 hf rex is god.... cheapest.... lightest... slow... it weighs nothing, you can put it in your pocket and carry it to the track.
with that rex comment of yours, I shouldn't have even replied...
Old 07-22-2003, 08:53 AM
TylerB's Avatar
Default Re: (VashTheStampede)
how slow are we talking.....stock
Old 07-22-2003, 09:55 AM
91_hatch_si's Avatar
50 hp to the wheel?
Old 07-22-2003, 08:39 PM
TylerB's Avatar
Default Re: (91_hatch_si)
omg, so would it go at all if i stripped it down to nothing, and would i even come close to beating anything besides geo's?
Old 07-22-2003, 10:01 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94prelude &raquo;</TD></TR><TR><TD CLASS="quote">omg, so would it go at all if i stripped it down to nothing, and would i even come close to beating anything besides geo's?</TD></TR></TABLE>
If the driver of the Geo is dragging his foot on the ground and the engine isn't running. hahahah
Old 07-22-2003, 10:02 PM
X-Static's Avatar
wtf? i dont think i have this..the only thing i can think of is that lil plate that the rearview mirror comes out of that lights up
Old 07-22-2003, 10:46 PM
TylerB's Avatar
Default Re: (4crx4me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me &raquo;</TD></TR><TR><TD CLASS="quote">
If the driver of the Geo is dragging his foot on the ground and the engine isn't running. hahahah </TD></TR></TABLE>
lol
efboy
11
01-20-2008 03:59 PM
SupraRXZ
28
04-15-2006 06:08 PM
vtec_joe
12
03-20-2005 06:00 AM
black00civicsi
16
12-11-2004 11:59 AM
SexyAzNMami
17
12-09-2004 11:45 PM
Quick Reply: differences in crx model
