Deleting the rear wiper. Any tips??
Old 04-28-2012, 12:50 PM
Vagitarian's Avatar
Default Deleting the rear wiper. Any tips??
This rear wiper is ugly as sin and has got to go.
Has anyone used a plug with success or a cool cover after removing the wiper to fill the hole??
Is there much inside the hatch that can be removed with the wiper??
Pics would be
Old 04-28-2012, 04:13 PM
gringo7718's Avatar
Default Re: Deleting the rear wiper. Any tips??
Search "wiper delete plug" on google
I removed the rear wiper and motor and cut a small block off plate to cover it. I painted it black (to match my car) and siliconed it in from the inside. I used silicone because it isn't permanent and I can undo it in the future if necessary. Since I have the jdm wing so I wasn't too concerned about how it looked since you cant see it anyways.
If you wanted to do it right, you can weld in a piece of metal and use bondo/body filler and sand it down and repaint it.
Old 04-28-2012, 04:18 PM
Randysi's Avatar
http://passwordjdm.com/PasswordJDM-R...P8336C329.aspx
http://passwordjdm.com/PasswordJDM-R...P8349C329.aspx
Old 04-28-2012, 04:37 PM
Hidenplanvew's Avatar
A bud of mine used a cam seal, had to kindof grind it to fit then just 3m window welded it back in..
Old 04-28-2012, 07:06 PM
wreckin-rex91's Avatar
This is by FAAAAAAAAR!!! the cleanest and most simple way of doing this and doing it right!
Old 04-28-2012, 10:44 PM
Stunna MIKE's Avatar
un plug, un bolt /thread
Old 04-29-2012, 04:36 AM
Vagitarian's Avatar
Ya I get the part of taking it out (even though Ive never seen the inside hatch) but deleting the hole is what I was asking about
Seems like this $30 plug is a good idea but I'll probably end up fiberglassing it or something
Old 04-29-2012, 05:30 AM
KINGVEM^^ED6's Avatar
I went to home depot bought a 39¢ plastic plug and its been fine for over a year now
Old 04-29-2012, 06:28 AM
Vagitarian's Avatar
Just happened to be the right diameter?
Old 04-29-2012, 08:23 AM
M-benz's Avatar
What plugs ? Which one man? Lol I need to know too
Old 04-29-2012, 08:29 AM
pimpwagon's Avatar
http://compare.ebay.com/like/4001878...Types&var=sbar
Old 04-29-2012, 08:34 AM
M-benz's Avatar
What about the turn handle ? Are you gonna just leave it like that? Man that's just ugly $hit lolz
Old 04-29-2012, 08:42 AM
Just go to HD and ask its not that hard
It was near the nails n building supplies
Old 04-29-2012, 08:50 AM
pimpwagon's Avatar
i was half joking. i did it to mine and used a boat plug. i had the plug. i thought it was funny. someone actually thought it was a battery disconnect switch once. LOL
Old 04-29-2012, 09:16 AM
M-benz's Avatar
Yea but u still want to know the name of that plug so that u can talk to them man
Old 04-29-2012, 09:19 AM
hai have no clue bro it was a long time ago
Tell them u got a two inch hole and need too plug it
I'm sure they will help
Old 04-29-2012, 09:42 AM
M-benz's Avatar
Oh ok two inch hole then ......
Old 04-29-2012, 09:50 AM
Idk exactly get a tape measure geez
Old 04-29-2012, 09:52 AM
I got something LIKE this BUT PLASTIC
Measure the hole first
Old 04-30-2012, 09:22 AM
schueytenten's Avatar
Lowes has a pretty good selection of those plugs, and prolly a bit more organized the HD.
Old 04-30-2012, 09:48 AM
M-benz's Avatar
Oh ok
Old 04-30-2012, 04:41 PM
Vagitarian's Avatar
I found the perfect plug at ace hardware, it was a rubber plug meant for a sink. Had a smooth/flat top and was meant to drop into a sink to stop water from going down the drain or whatever, and it was already black, and only cost 79 cents
Im probably going to weld it and smooth with filler when I paint the car though
Old 04-30-2012, 06:36 PM
Wth
Old 04-30-2012, 07:11 PM
M-benz's Avatar
U think you can shoot a pic of that plug ?
Old 05-07-2012, 02:22 PM
M-benz's Avatar
Ok just bought me an OEM plug ( made in Japan ) not sure if you can use this part number to get it from Honda or not but I'mma go head share anyways...
Quick Reply: Deleting the rear wiper. Any tips??
