dc wiring harness in crx?
anyone every done this?
i have to buy an entire harness cabin and motor.. cant seem to find a rex one but i found a 95 teg complete harness for 100..
i dont plan on running heat im just leaving the bare minimum in hte car
EFSS153
Re: dc wiring harness in crx?
That sounds like a ton of work for no real benefit. I actually have an entire cabin harness from an '89 hatch if you want it. $60 shipped. Check out the part out thread in my signature for details.
i have a full cabin harness from a 89 crx, ill have to check tho. and there is a complete dx crx at the local yard. just wait and get the one that is meant for your car. it will require too much work to get the DC harness plugged n working right. plus there are a crap load of them on ebay as well.
how hard could it be? im not using heat/ac so the only things that would be hoked up was tailights headlights radio cluster everything for the engine
your dashboard harness is NOT the same, and will need to be modified (or custom made) to work with the DC harness. not to mention the under dash fuse box will have to be re-located because they have a smaller one that bolts to the side kick panel (unless your gonna leave it hanging there). if you decide to use a stock fuse box, then you will need more custom work. as well as the actual dashboard harness. this will also need to be modified to work with the DC harness. and im not talking about the heate/ac controls. the cluster is different.
oneslodx
02-19-2004 02:25 PM
