d16z6 into a crx SI ???
aight i just got a 1988 crx SI ... and the motor is toast in the car ... so i decided i was just gonna put something cheap in it just so it would run but something better than the stock motor ... so my friend told me to do a d16z6 swap ... but i was wondering what all i need to get in order to drop it in ....
i know i need the motor, ecu, and harness .. but what else would i need ..... thanks
well for the z6 swap u will need a p28 ecu ecu conversin harness try to get the obd1 dizzy with it if not ull need one of them too next ull need a dizzy jumper harness so u so can use your si harness with obd1 dizzy.everything for the conversion can be bought from here.
http://www.rywire.com
FYI what everu do please dont try to run it with a obd0 dizzy and a pm6.and i vtec controller to make vtec work trust me it will never run right.
so if i get the obd1 dizzy, dizzy jumper harness, p28ecu, and ecu conversion harness ... it will drop right in ... and i wouldnt have to use a vtec controller then would i ... cause i wasnt planning on using one unless i had to .. but thanks for the link i'll check it out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lancerkid06 »</TD></TR><TR><TD CLASS="quote">so if i get the obd1 dizzy, dizzy jumper harness, p28ecu, and ecu conversion harness ... it will drop right in ... and i wouldnt have to use a vtec controller then would i ... cause i wasnt planning on using one unless i had to .. but thanks for the link i'll check it out</TD></TR></TABLE> You can make the harnesses yourself if you are ever so electronically inclined and save some cash. And please mail your VTEC controller and any your friends may own back to 2001 please
I am running z6 with p28 and conversion harness...swap is really easy. If you need a dizzy I got a brand new one I got from dizzy king lying around that I haven't used and need to unload pm me if interested
SOHCEK-Turbo
Aug 12, 2003 01:41 PM
