d15 vtec motor Ouestion???
Old Nov 19, 2004 | 02:32 PM
JDM RHD eg6's Avatar
Default d15 vtec motor Ouestion???
help me out!!!
what do i have to change if i swap a d15 vtec motor in my 1991 crx si.
Im going to use my crx L3 tranny.
HELP ME OUT
Old Nov 19, 2004 | 02:37 PM
I8ayellowcrayon's Avatar
Same as D16Z6 (OBD1 Civic EX) swap. I would say just get an OBD0-OBD1 conversion harness and then you'll have to insert some wires for the VTEC selanoid. Also, use your stock CRX mounts.
Old Nov 19, 2004 | 06:49 PM
PhatwhipsJDMkits's Avatar
Default Re: (I8ayellowcrayon)
You need to convert to OBD-1 using a conversion harness get either P08 ecu which is the correct ecu for your motor or P28 which is the z6. Id recomend using your Obd-0 injectors so you dont have to deal with the injector resistor box. Also you use all your Crx mounts but you will need to switch the mounts by the timing belt from your old motor to the new one.
juanfromcali
Mar 19, 2009 05:02 PM
lancerkid06
Feb 2, 2008 04:16 AM
perseverance
29
Jun 5, 2007 07:25 AM
s.wilson
Apr 14, 2005 07:32 PM
folta2169
13
Dec 6, 2004 03:30 PM
