CRX no start, no power, good batt
91 CRX DX. 215k miles.
Battery tested good on battery tester. Reads 12.8volts.
Grounds are good. ALL fuses in/out of the car (except for interior lights fuse inside, been broke a while) are good.
Starter, Alternator, and Battery have all be replaced in the last year and were working great.
Car doesn't start. Turn the key, no power to to the cluster. None of the normal lights light up.
No CEL, no oil light, no brake, no door ajar.
Replaced Ignition Switch, old one was worn out. Still no power/no start.
Any ideas?
Any ideas?
Re: CRX no start, no power, good batt
Do you have a picture of your engine bay near the battery source? I can probably spot your problem. Just take a pic of that part of the engine bay.
It is simple whatever it might be,check your batt. termals,grounds,and main fuse your just lookin over something.
had this happen on our lemons car. it was a bad wire from the battery to the starter. we literally yanked on it and it worked again. NO IDEA why.
extensioncordy
34
01-30-2007 03:38 PM
