can you add v-tec to a non t-tec head?
Electrician
Should be able to swap in a D16Z6/D16Y8 cylinder head, but also need to cosider the electronics.
The D16A6 is from the pre-1992 right? If it is, is it OBD-0? If so, the Z6 head is OBD-1 and the Y8 head if OBD-2. Definitely need to consider that also.
But, I believe you can get good compression ratios with A6 pistons and a VTEC head such as the D16Z6. Most people swap in the A6 pistons with a Y8 cylinder head and a thinner head gasket to yield GOOD compression numbers.
Do some more Search on here, lots of information.
Re: (Dimi)
[QUOTE=Dimi]Should be able to swap in a D16Z6/D16Y8 cylinder head, but also need to cosider the electronics.
[QUOTE]
Actually, the cylinder heads have nothing to do with OBD-anything.
its the intake manifold electronics and the distributor & ECU. Use d16a6 components and you're set, or convert your harness to OBD1 and use P28 ECU
[QUOTE]
Electrician
That's what I was saying. The cylinder head electonics. Such as VTEC solenoid, distributor and intake manifold. Those are part of the cylinder head.
Re: can you add v-tec to a non t-tec head? (lillthingz)
fact, you can't use a non vtec head and turn the non vtec head into a vtec head!!! and even if there was any way it hell you could it would cost more then what's it's worth, the best bet is to buy a D16y8 head off a 99or 00ex, (higher comp.) and slap it on, run a vtec, diss. and get a p28 ecu and wire the vtec wires, and call it a day. O yeah and mill in 30xxx's for that extra kick
Re: can you add v-tec to a non t-tec head? (DewMota)
where is that piture with the V-tech phone on top of the valve cover?
I guess I need to take a new one
Modified by Jon V at 4:07 PM 8/14/2004
Re: can you add v-tec to a non t-tec head? (Jon V)
well when i needed vtec i bought a bottle of vtec juice and just added it to my oil
Re: (Mugen562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen562 »</TD></TR><TR><TD CLASS="quote">man...that sounds like a lot of work. save $ for a swap.
my 2cents</TD></TR></TABLE>
stfu its not alot of work
you just dont know what your talking about
I don't see how it would be hard to put a d16a6 non v-tec head on a d16z6 block. I have a d16z6 motor i just got the a6 headand it was ported so i said hell why not try putting it on, maybe i ill get some gains? i duno that's why i asked yall about it, hoping i would get some insight from people with more motor knowledge.
ClutchPapi
06-04-2013 07:13 AM
