can somebody double check my vacume lines for my crx hf w/b16
Old 08-23-2003, 12:12 PM
crx1856's Avatar
Default can somebody double check my vacume lines for my crx hf w/b16
this is my hf vacume lines running to my first gen b16. one side of the map sensor line is capped off. the other side is running to to the back of my manifold where i have it tee'd a couple of times with my fpr line, boost gauge, and blow off valve. the line running from the purge valves are going to my black canister and the throttle body.
Old 08-23-2003, 12:26 PM
RCautoworks's Avatar
Default Re: can somebody double check my vacume lines for my crx hf w/b16 (crx1856)
Here recheck them using this pic, its hard for me to see if everything is ok because the pic is only focusing on the map sensor.
From what I can see though, everything looks good.
Old 08-23-2003, 12:28 PM
crx1856's Avatar
Default Re: can somebody double check my vacume lines for my crx hf w/b16 (90blackcrx)
i only have 1 solinoid not two. how does that come into play?
Old 08-23-2003, 12:31 PM
crx1856's Avatar
line #10 goes into a port in the manifold i don't have. 1 and 12 are tee'd into where line 10 would go. is that right?
Old 08-23-2003, 03:43 PM
fourthgenhatchB17's Avatar
MAP hose goes to a vacuum fitting on the throttle body itself (like it shows in the hose routing pic). I wouldnt tee anything off of that particular line. As for the others u should be fine.
juanchoenuncrx
12-26-2007 05:03 PM
crx1856
08-18-2003 10:55 AM
crx1856
08-18-2003 08:46 AM
crx1856
08-16-2003 02:57 PM
crx1856
08-11-2003 07:29 PM
Quick Reply: can somebody double check my vacume lines for my crx hf w/b16
